April 4, 2011, 13:26 |
rotating mesh help
i was designing a 2D model of a windturbine blades on work bench,and in order to get results for the wind pressure, the torque and ..., i need to have rotating meshes, but i cant do it, and since i'm using workbench only none of the tutorials are helpful, i was wondering if anyone knows how to do this?
thanks in advance |
April 5, 2011, 21:53 |
Simon Pereira
Rep Power: 47 |
Model the rotating portion as a separate part (not part of the multi-body part)... It will be meshed separately (all at once, but not conformal). You can also apply a different named selection to that volume so that when you get to Fluent you can easily select it and setup the rotation...
The mesh is always static in the mesher, you just need to be able to select the rotating zone and it needs to be fully surrounded by faces (shells) to support the rotating boundary condition... The rest is done in the solver.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Rotating mesh | Jesper | CFX | 14 | April 27, 2012 18:57 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
problem with rotating mesh | viet | CFX | 5 | March 10, 2007 00:16 |
Multiple rotating frame VS dynamic mesh | Jen | FLUENT | 3 | July 2, 2005 07:31 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
