growth rate of mesh in ICEM
Like Tree3Likes
  • 3 Post By PSYMN
Old   March 10, 2011, 07:24
Default growth rate of mesh in ICEM
Nick
Nick R is on a distinguished road
This is a basic question from a newbie. How do you control the growth rate of mesh in ICEM. Say you have a 3d wing in a box-like domain and you wish to control the way the mesh grows from the 3d wing. Is there a way you can control how fast the mesh would grow from the wing into the domain? Is there a face size growth parameter?
BTW this question is in the tetra unstructured strategy approach.
Thanks.
Nick
Nick R is offline   Reply With Quote
Old   March 11, 2011, 06:25
alastormoody11 is on a distinguished road
There are two ways to do this
First is to assign a very small mesh size on the surface of the 3D wing, which would essentially ensure a fine mesh size at least in the proximity of the wing, also the region in a in which grid is fine can be increased by using slower transition.
If you want a considerable area around the 3D wing to have a very fine mesh you will need to create a mesh and then assign a small value for the grid size inside the density.
You can use the two in combination.
alastormoody11 is offline   Reply With Quote
Old   March 11, 2011, 11:53
Default Tetra Ratio...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Under the mesh tab => Params by Parts, you have various columns for settings. You can also apply these to individual surfaces or curves... The Tetra ratio is the growth rate into the volume. The Width will fix the size on a number of elements into the volume before the transition begins.
With Octree Tetra, the sizes really grow by powers of 2. So the ratio applies over the longer term.
Delaunay 1 1.2 1.4 1.7 2.1 2.5 3.0 3.6 4.3
Octree 1 1 1 1 2 2 2 2 4
In the above two rows, the ratio is set to 1.2 for both, but the Octree mesh appears to stay as size 1 for 4 layers and then jumps to size 2... Over the long term, the octree growth rate is approximately 1.2.
If you want actual smooth transitions, just remesh your Octree mesh (keeping the surface mesh) with Delaunay.
Alastormoody is talking about density boxes (or points or lines), which is a way to set the local max size within a volume. You can also set a growth ratio on each density which affects the transition away from the density.
wc34071209, Dronzer and Mohammad74 like this.
PSYMN is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
varying curve mesh spacing at icem surface-mesh? mirko_r ANSYS Meshing & Geometry 6 January 14, 2010 14:23
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 07:07
How to corse mesh in icem cfd? Priety CFX 2 October 2, 2006 04:57
