[ANSYS Meshing] import mesh to Workbench mesher |
January 13, 2011, 22:09 |
Rep Power: 16 |
Is there a way to import any kind of mesh to Ansys Workbench mesher? I can not find that function...
Thanks for the answer in advance! |
January 14, 2011, 12:05 |
Skin it.
Simon Pereira
Rep Power: 47 |
Not yet...
At the moment, the ANSYS Meshing tool requires geometry to apply bocos, etc. so it can't take in a mesh without a geometry... HOWEVER... The Free (in Workbench) FE Modeler tool can import a mesh (such as a Nastran Mesh) and "Skin it", then you can send it from FE Modeler to ANSYS Meshing with the existing mesh or to remesh it, etc. Also, our Extended Meshing tools like ANSYS ICEM CFD or ANSYS TGrid can import 3rd party meshes (without geometry). |
January 14, 2011, 13:36 |
Rep Power: 17 |
Yes it can
January 14, 2011, 16:37 |
Imported Mesh system...
Simon Pereira
Rep Power: 47 |
Oh yes, But that doesn't get the mesh into ANSYS Meshing, it just gets it onto the schematic so you can import it into ANSYS Fluent or CFX by dragging and dropping those systems onto the Imported Mesh field.
This would be similar to just opening one of these programs (just use a Fluent or CFX system and launch them without a mesh) and then import the mesh directly into the solver. Schematic_ImportedMesh.jpg We are working on this and should be able to do a lot more with an imported mesh at some point... ;^) |
January 14, 2011, 18:52 |
#5 | |
Rep Power: 16 |
January 14, 2011, 19:30 |
a bit of description and new question
#6 | |
Rep Power: 16 |
My whole problem arises from an axial fan cfd simulation, in which the rotor itself is surrounded by a fairly complicated geometry (not just a channel). So in this case Turbogrid mesher fails to build nice mesh for the complicated inlet/outlet domains, though It can make a suprisingly good quality mesh around the blades (especially with ATM optimized topology, the guy who invented that must be a genius). So the Turbogrid mesh is confined only to the rotor, but then I must connect the inlet/outlet meshes to it. But, as I'd like to simulate only 1 blade passage, it is advisable to minimize the numerical error arising from different interface areas (pitch ratio not equal to 1) between the inlet domain's outlet and the rotor inlet (as well as between the rotor outlet and the inlet of the outlet domain). I reached the point I wanted: so I'd like to start my inlet/outlet domain meshes from the rotor's mesh which is generated by Turbogrid (see my other post too: http://www.cfd-online.com/Forums/ans...tml#post290353). That is why I wanted to import the rotor mesh to Ansys mesher to build the inlet mesh using rotor's inlet/outlet. This solution looks a dead end (at least with current Ansys mesher), but I was able to export the mesh to Icem CFD and generate inlet geometry (by converting face mesh to geometry) and could do the inlet/outlet domain meshes there in Icemcfd and export those back to workbench to CFX-pre. My question is: can I do this latter method with Icem CFD without loosing the possibilty to exploit the nice parametric study capabilities of workbench (as Icem CFD is not a component system of workbench (why not actually?) ? Can I use some scripting feature of Icem CFD to update the inlet/outlet domain meshes, but keeping the simulation (mesh generation) automatic in workbench to make parametric case studies? Thanks for the answer in advance, again! And sorry for the long post... |
January 14, 2011, 22:10 |
hmm...could be a good idea
#7 | |
Rep Power: 16 |
Plugin error: Attach failed Unable to attach geometry Any other ways to send the geometry from FE Modeler other than in its own .fedb file? I used the templates as well: the stl template is not too good, as it would output all my cells just tris insted of quads, right? Is there a template for outputting to .iges from FE modeler? That would be nice... |
January 15, 2011, 01:38 |
Skin...
Simon Pereira
Rep Power: 47 |
You must skin it...
The skinning (Geometry synthesis) is critical for getting the model into ANSYS Meshing or ANSYS Mechanical. It is also required before you can convert the geometry into bsplines for output to IGES or Parasolid. |
January 15, 2011, 17:36 |
confusion
#9 |
Rep Power: 16 |
Ahh ok. So does the "intitial geometry" feature only take into account the skinned geometry? So it disregards the components, right?
When I convert the initial geometry to parasolid will it respect the details of skin detect tool (e.g. tolerance angle) or will it respect the geometry sythesis parameters like vertex insertion angle? Thanks! What about the other method with Icem? Can Icem be connected somehow to a workbench project (eg via scripting) in Ansys 13? |
June 27, 2012, 17:45 |
#10 |
Saima
Rep Power: 16 |
Can i import mesh from ICEM to ANSYS mechnaical with geomtery, as I have to implement boundary condition in ANSYS?
Regards
Best Redards, Saima |
October 23, 2013, 15:35 |
#11 |
AS
My .msh file is not getting imported in fluent.
Please help me out. |
import, mesh, mesher, workbench |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 03:22 |
icem: import tecplot mesh | David | CFX | 4 | August 9, 2006 09:30 |
Import ICEM Mesh to Fluent | Fluent Beginner | FLUENT | 5 | June 23, 2004 01:27 |
