[ANSYS Meshing] Creating named selections in ANSYS
Like Tree3Likes
  • 3 Post By PSYMN
Old   January 13, 2011, 00:02
Default Creating named selections in ANSYS
Alvin Yeo
ejayalv123 is on a distinguished road
I had some issue on creating different sections on my fluid model.
As you can see from the picture, I would like to create a new named selection on the section as pointed by the arrow but was unable to do so as the cylinder is a whole part itself.
I had attempted to draw the sections separately but problems occurs when i attempted to mesh to model as the region of contact between the sections has very low meshing quality.
My final goal in here is to create named selection on that section so that i can define a new boundary condition for me to use it at Fluent later. I would appreciate any help that is given
[IMG]file:///C:/Users/ALVINY%7E1/AppData/Local/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/Users/ALVINY%7E1/AppData/Local/Temp/moz-screenshot-1.png[/IMG]
ejayalv123 is offline   Reply With Quote
Old   January 14, 2011, 18:04
Default Imprint
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Create a sketch in the plane above the cylinder or on the surface of the cylinder, and then extrude the sketch... But instead of using the option to Add Material, choose "imprint surface" instead.
This will create a separate surface patch for you to select, but without actually subdividing the body...
thermal energy, yardena and f.kh like this.
PSYMN is offline   Reply With Quote
Old   January 16, 2011, 07:17
Alvin Yeo
Problem solved. Thank you very much Mr. Simon!
Old   March 18, 2018, 11:14
Alabi Abeeb Opeyemi
MrBreezie is on a distinguished road
Please I am facing this same issue. My named selection is not displaying in the fluent. Please help me out
MrBreezie is offline   Reply With Quote
ANSYS12 - named selections not transferred enigma Main CFD Forum 8 July 16, 2024 08:23
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Creating volume for two surfaces in Ansys marbro ANSYS Meshing & Geometry 0 May 22, 2010 12:13
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
