How to merge bodies
Like Tree1Likes
  • 1 Post By PSYMN
Old   July 29, 2010, 07:01
Default How to merge bodies
Oxmox is on a distinguished road
Thanks for reading this thread!
I'm trying to define different zones for meshing of a cylindrical pipe.
I've got one shell-pipe and one core-pipe(with different sizing...) but I want Fluent to calculate them as only one pipe.
How can I merge two or more bodies into one AFTER the meshing?
('body of influence' is not an option right here...)
Thanks in advance for any replies!
Oxmox is offline   Reply With Quote
Old   July 30, 2010, 09:51
Default What Mesher?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
What Meshing tool?
PSYMN is offline   Reply With Quote
Old   August 2, 2010, 06:47
Default std workbench mesher
I'm using the standard meshing tool in workbench v.12.1, 'Mesh'...
Old   August 2, 2010, 11:24
Default Multibody parts
PSYMN's Avatar
Simon Pereira
If you are looking node for node conformal meshes between the inner and outer pipe, but you currently have two separately meshed bodies... You can't merge them after meshing. However, you could go back (to DM) and turn them into a MultiBody Part. (Done thru right clicking on the parts branch of the model tree).
When you mesh a multibody part, it generates conformal mesh between the bodies.
If you actually want to merge the volumes into a single volume (all one material) so it will actually mesh as a single volume, then you would do a body operation in DM to union the parts.
If you want to merge existing meshes (such as a tetra mesh and a swept hexa mesh), then you need a mesh editor like ICEM CFD.
starry09 likes this.
Old   August 20, 2010, 05:21
Thanks a lot, worked out perfect...
merge zones Domi FLUENT 2 May 3, 2019 14:15
Stress Discontinuity between sliced Bodies - WORKBENCH mankle ANSYS 0 May 6, 2010 03:54
assemble the mesh feixiangniao ANSYS Meshing & Geometry 2 March 20, 2010 03:39
Mesh motion for two bodies siw CFX 0 April 8, 2008 05:20
about merge mesh lian Main CFD Forum 3 February 29, 2008 11:47
