[ICEM] Geometry too large!
Like Tree2Likes
  • 2 Post By PSYMN
Old   April 29, 2010, 12:00
Default Geometry too large!
Bruno
brunorgs is on a distinguished road
Hi there,
I am facing a strange problem in ICEM, and I wonder if someone could help me.
I have a fairly large (in terms of memory) geometry in ICEM (~430 MB). I needed just a small part of the model, so I erased almost the whole geometry and saved it, but the geometry file still have almost 430 MB! After I erased the whole geometry , all parts and dormant entities, but the geometry files is still near 430 MB. Someone have any idea of what is happening? Can the file be corrupt?
Thanks!
brunorgs is offline   Reply With Quote
Old   April 30, 2010, 10:51
Ming
h.m lee is on a distinguished road
Really? I wasn't aware of it before.
Can you explain the details of how you "erased the whole geometry , all parts and dormant entities"?
Thanks
h.m lee is offline   Reply With Quote
Old   April 30, 2010, 14:39
Bruno
Thanks
Hi. First I restored the dormant entities ("Restore Dormant Entities" button). Then I used the "Delete Any Entity" button with the hotkey "a", so that all geoetry is erased, visible or not, right? After, I erased all Parts manually and saved the geometry.
Old   April 30, 2010, 15:01
Ming
I think surface is the most important, when a surface is deleted, its attached curves and points can be deleted permanently. But if a surface is still existed, it need points and curves to position itself.
Is there any help to your situation?
Old   April 30, 2010, 17:57
Bruno
Not sure if I understood. Once the surfaces and everything else is gone, what else can be done?
Old   April 30, 2010, 19:30
Ming
try steps to delete entities:
1. delete the surfaces that you don't need at first;
2. delete the curves and points that were attached to the surfaces you had deleted.
let me know your result.
Old   May 3, 2010, 10:19
Bruno
I tried that, but the same thing occurred...
Old   May 3, 2010, 12:19
Ming
I don't know what's the matter. In my experience, when some parts of geometry are deleted, the file size will decrease nearly proportionally.
If you can send me your file in compressed format to li.hming.ca@gmail.com, I would like to try your case. Alternatively, you can take a shot at commands like ' save some geometry file as'.
Good luck
Old   May 3, 2010, 16:08
Bruno
I tried to save only the visible geometry, but it didn't work. If you don't mind to take a look, I've uploaded the geometry to this link:
http://www.4shared.com/file/LkbEqVmW...ura_Flare.html
Fortunately, the zipped file is much smaller than the original: 10 MB.
Thanks for the help,
Bruno
Old   May 20, 2010, 22:18
Default Shrink Tetin File
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Tetin files are ASCII... (Text Files).
You can open them with a text editor (I recommend TextPad for such a large model, NotePad will choke).
In your example, you will see tons of messages about how often this model has been saved, etc. There are also lines about undo, etc.
You could try to delete these lines in here, but it will take you all day.
Another option is to go into ICEM CFD, you don't even need to load the big file. Under the Edit Menu, you will find an option for "Shrink Tetin File"
This function will prompt you to select the file you want to shrink, and then it will give you an opportunity to name the new file.
I your case, it shrunk this 426MB file down to 800K.
TrII4d and PavithranR like this.
PSYMN is offline   Reply With Quote
Old   May 20, 2010, 22:20
PSYMN's Avatar
Simon Pereira
Here are the messages from the message window... That is a lot of lines to remove... Usually, there are just a few dozen junk lines. Not sure how you got it so high.
Select tetin file to shrink
Save shrinked tetin file as
Reading tetin file Shrink.tin...done
Found 5441197 line(s) to remove
corrupt geometry, large geometry
[GAMBIT] Splitting a geometry problem enfinity ANSYS Meshing & Geometry 4 September 13, 2012 10:33
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 09:17
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 11:50
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
