[ICEM] How can I define different zones in ICEM? |
October 6, 2009, 17:39 |
Li
Rep Power: 17 |
Hi, I am trying to model a geometry in attachment. Would you please tell me how I can define the porous media zones in the model? Thank you.
October 7, 2009, 11:35 |
Parts...
Simon Pereira
Rep Power: 47 |
You just need the mesh to be in a different "part" so you can apply different properties.
If it is a 2D mesh, then just change the part of those surfaces (Create a new part and add those surfaces to it). If it is a 3D mesh, then just create a new material point for each region. Tetra will use a floodfill command to assing the elements in that region to that material part and then you can assign separate material properties to each separate region. If it is Hexa, still create the material points, but you will need to interactively assign the specific blocks to their specific Material Part... If you have two separate material regions, ICEM CFD will assume a wall between them... You may need to delete the shell elements between them (or at least set up the bocos on that shell part so it is not a wall). In hexa you can set it up so it won't assume wall projection between specified materials. Simon |
October 7, 2009, 14:21 |
Li
Rep Power: 17 |
Hi Simon,
Thank you very much for the answer in detail. I have another question in 2D model. Should I have to create surface in 2D model if I use block to generate the mesh? I defined several material regions but after I output the mesh I still only got one zone. I think the problem is maybe that I didn't assign specific blocks accordingly. Please correct me if I am wrong. Thanks a lot. BTW, I saw the tread about the hybrid mesh and you post a link. unfortunately, I cannot open the link. Li |
October 7, 2009, 17:45 |
No surfaces...
Simon Pereira
Rep Power: 47 |
Ok, so this is a 2D surface blocking with no surfaces... No problem. When you intialized the blocking, it created everything in some material (called FLUID or SOLID or whatever). Create some more material points in the names of your POROUS regions... Then right click on those material points in the tree and choose "Add to Part". The third ICON on the Add to Part DEZ (Data entry zone) is the "Blocking Material, Add Blocks to a Part". Select that, then select the 2D blocks you want to add to the porous parts...
Simon |
October 8, 2009, 10:33 |
Li
Rep Power: 17 |
Hi Simon,
I tried what you said, but when I right click on the material points and chose 'Add to part', I can only click the first icon. The other two are not availabe, I mean, they are in grey. Thank you. Li |
October 8, 2009, 10:34 |
Li
Rep Power: 17 |
Oh, I got it.
October 8, 2009, 10:55 |
Blocking Loaded...
Simon Pereira
Rep Power: 47 |
Since I am already here, and others may read this...
I am guessing that you just needed to have the blocking loaded so you could access that icon. I am glad you figured it out. Best regards, Simon |
October 8, 2009, 11:27 |
Li
Rep Power: 17 |
Hi Simon,
I did what you suggested in #4. Then I generated the mesh and imported it to Fluent6.3. I got some warnings which are: //Warning: Thread 3 has 2 contiguous regions. Warning: Thread 1 has 2 contiguous regions. creating geom:008-shadow creating geom:006-shadow creating geom:004-shadow creating geom:003-shadow creating geom:001-shadow shell conduction zones, Done.// On #2, you mentioned if there are two material point or more than two then ICEM will assume a wall between them, but with Hexa mesh I can set it up. I generated the hexa mesh, does it mean the mesh I got is ok? Of course, I mean the connection between porous media zone and the room. Thank you. |
October 8, 2009, 12:13 |
#9 |
Li
Rep Power: 17 |
I checked the define/boundary conditions..., and there a lot of new items:
diffusion1-------------------I defined, material point diffusion2-------------------I defined, material point drainedfloor-----------------I defined, material point geom-----------------------ICEM geom:001-------------------New item, I am gonna define as porous jump geom:001-shadow-----------New item, I am gonna define as porous jump geom:002-------------------New item, I am gonna define as the wall, the short edge of the porous media area geom:003-------------------New item, defined as porous jump geom:003-shadow-----------New item, defined as porous jump geom:004-------------------New item, defined as porous jump geom:004-shadow-----------New item, defined as porous jump geom:005-------------------New item, defined as porous jump geom:006-------------------New item, defined as porous jump geom:006-shadow-----------New item, defined as porous jump geom:007-------------------New item, defined as wall, the short edge in porous meida area geom:008-------------------New item, defined as porous jump geom:008-shadow-----------New item, defined as porous jump geom:009-------------------New item, defined as wall, short edge in porous media slattedfloor------------------I defined, material point ini-diffusion1-----------------New item, defined as porous jump ini-diffusion2-----------------New item, defined as porous jump ini-drainedfloor---------------New item, defined as porous jump ini-slattedfloor---------------New item, defined as porous jump solid-------------------------ICEM, defined as fluid I am not sure the patterns like geom:001 and geom:001-shadow, should I define an interface between them in Fluent ( I think I should)? Please also have a look at the attachment. It probably help to understand what I am talking about. Thanks a lot. Li |
October 12, 2009, 10:40 |
L8r.
#10 |
Simon Pereira
Rep Power: 47 |
Sorry, I am out of time today... I will try to get back to this later. But my first thought is that shadows are double walls (the wall and its shadow)... I will look properly at the messages and bocos later.
Simon |
October 12, 2009, 11:27 |
#11 |
Li
Rep Power: 17 |
Yes, you are right. I think I already figure out how to define them. Some of them are interior and some of them are walls:-) But if I am wrong, please correct me. Thanks.
Li |
February 5, 2013, 03:50 |
#12 |
Fozika
I was facing that problem >>>> So thanks much Simon and Li.
November 14, 2013, 13:06 |
#13 | |
Dimitris Romanas
Rep Power: 13 |
where exactly can do that??in ansys meshing?? i have 2 fluids and i want to be one the air and water the other. How can define them before mesh?? Thank you in advance! |
August 4, 2014, 21:04 |
#14 | |
Hooman
Rep Power: 15 |
I have a quick question for you, I have a geometry and only a small region is porous. I do not know how I can define this so when I import it to Fluent I can choose the small part as Porous and the rest just non-porous! Basically how can I have different zones? I do not understand the material point technique, how does Fluent/ICEM understand the exact boundaries of my Porous region? In order to define a body I need two material points, that is what makes me confused. I am trying to use all tetra mesh elements. Your help is greatly appreciated. Thanks, |
February 12, 2017, 14:44 |
Good
#15 |
Alberto Menéndez
Rep Power: 10 |
Good advices
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 22:13 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
