[GAMBIT] gambit with xming doesn't work
Like Tree1Likes
  • 1 Post By calemarie
Old   April 11, 2009, 10:26
Default gambit with xming doesn't work
LI Dan
hbsld is on a distinguished road
I want to run gambit in locale.
I have installed and configed xming followd the suggestion in
http://rc.usf.edu/trac/doc/wiki/XmingInstall
But gambit also prompt that unable to open display.
I wonder why ssh must be involved, and how what the remote machine should be set in Xlaunch configure.
I set 127.0.0.1, but the ssh.exe just show in a cmd window, and close the window immediately.
hbsld is offline   Reply With Quote
Old   April 22, 2009, 06:59
Charles-André LEMARIE
calemarie is on a distinguished road
Hi hbsld,
I had some troubles with Xming and Gambit as well, but not as you described. I had no problem to make the connection to display, however, no way to get the grid shown inside Gambit (the graphic window remains black, while all other buttons and controls work perfectly well).
I understand that you have some misconfiguration with Xming, but I think it is worthless to put any effort on solving this: as I figured it out by myself, this site also claims to be aware that "Xming and Gambit [...] don't operate well together".
An alternate: use Cygwin/X...
Hope this helps
Calemarie
calemarie is offline   Reply With Quote
Old   April 22, 2009, 08:32
hbsld,
I revert to what I wrote earlier: indeed, after disabling OpenGL, I managed to have a working Xming-Gambit session. To do so, I simply used the "-dev X11" option to launch Gambit, as explained here.
Regards,
calemarie
peppino likes this.
Old   April 22, 2009, 12:52
LI Dan
thanks for your reply.
I have tried to install cygwin X server. The Xwin server can launch normally, but the xterm can't show. If I use startx in cygwin bash, it prompt that:
xterm Error 29 errno 11: resources temporarily unavaiable
Gambit prompt :
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/ld-pc:0
Unable to open display
Old   April 23, 2009, 07:24
It seems from our google friend that there are issues with such an error 29, especially under Vista (have a look here for instance). A summary of my findings:
- whether under Vista or not
. maybe a firewall issue -> check your settings
. maybe a DLL address space collision issue -> install the cygwin 'rebase' packing and follow instruction of the readme
- if under Vista
. well, 'rebase' again...
Maybe this can help... I am running XP and faced no such problems so maybe the Vista thing is the key...
Regarding the Gambit messages, it seems like it is a consequence of the cygwin error (see here).
Regards,
calemarie
Old   January 29, 2012, 17:27
Default xming problems
Sam
spliter200 is on a distinguished road
can anyone help I am having some problems?
when i run xming and gambit on my computer it runs fine provided that i lunch it with -dev X11. I can mesh and export to fluent and everything works. the problem is that when you are working in Gambit the drop down menus begin to get bigger and bigger and bigger and before i know it goes off screen i cannot select faces or edges. so again the problem is that drop down menus get bigger and bigger as you open them, also the buttons of APPLY and CLOSE are fat and big. Does anyone know why this is happening??
i tried to install Cygwin to see if this would help but i cannot get gambit to run
i do the following
startx
then it opens another white terminal
and i put the following
/cygdrive/c/Fluent.Inc/ntbin/ntx86/gambit.exe -r2.4.6 (hit enter)
and it opens gambit i click run
then there is a message that says that failed to locate exceed
then at the end there i get a message
Cannot open connect stream.
TRANS(Open): transport open failed for tcp/LOCALPC:0
so again i get this when i try to run the cygwin/x
if anyone could help me out?
spliter200 is offline   Reply With Quote
Old   March 23, 2014, 10:24
Paulina
p_kmb is on a distinguished road
I have the same problem. Does anyone know how to solve it?
p_kmb is offline   Reply With Quote
[GAMBIT] Can´t start GAMBIT zalho ANSYS Meshing & Geometry 18 April 8, 2019 02:05
Gambit Startup Window Jay Shim FLUENT 2 February 12, 2015 15:05
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 07:29
Gambit Default Working Directory Virgil Howardson FLUENT 5 December 19, 2009 07:13
Problem starting Gambit ViHAR MALViYA FLUENT 0 November 10, 2006 11:26
