[ANSYS Meshing] Poor quality Mesh of a CD Nozzle
Like Tree1Likes
  • 1 Post By adit_YA
Old   October 7, 2024, 03:57
Post Poor quality Mesh of a CD Nozzle
adit_YA is on a distinguished road
Dear all,
I am getting poor quality mesh as can be seen in the attached picture.
Poor quality increases when I increase the number of cells or the bias factor of the edges towards the wall.
I am a beginner in this field, so I would really appreciate your help or advice in generating a good quality mesh!
Thank you!
adit_YA is offline   Reply With Quote
Old   October 7, 2024, 12:27
Daniel
zacko is on a distinguished road
Can u upload an image of how the mesh looks? Maybe in an isometric view? Do you use inflation layer at the walls?
zacko is offline   Reply With Quote
Old   October 7, 2024, 13:51
Hello zacko,
I have attached the photo.
No, I did not use inflation at the walls. I simply used biasing using a bias factor of 45.0 to account for the first cell height which was around 0.32 microns.
I believe inflation does not work with face meshing (structured mesh)? Do correct me if I am wrong!
Old   October 8, 2024, 16:50
Daniel
It is a 3D geometry, correct?
I think inflation should work, but instead of selection your wall as surface, you can use an edge instead and create the layer there.
Anyways, can you zoom in more to see how the elements look in the region where the bad quality is supposed to be? How about starting from new without all these many mesh refinements
Old   October 9, 2024, 04:26
Its a 2D geometry. Thanks for the suggestion!
zacko likes this.
cd nozzle, fluent, mesh, nozzle simulation, quality
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
GeometricField -> mesh() Function Tobi OpenFOAM Programming & Development 10 November 19, 2020 12:33
Convergent-Divergent Nozzle with MATLAB Obad Main CFD Forum 8 June 2, 2020 15:10
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
