[ANSYS Meshing] Reason to divide between rotating areas
Like Tree4Likes
  • 1 Post By Gert-Jan
  • 1 Post By evcelica
Old   September 11, 2024, 04:56
Default Reason to divide between rotating areas
Jang Geonwoo
kzzang3831 is on a distinguished road
Hello
I am a senior student at a university.
I wonder why we have to separate the rotating areas.
I think it's to limit the cells and nodes to the rotating areas and divide the more detailed areas to the rotating areas.
I wonder if there is no problem with eliminating the rotating round areas and calculating them.
I'm sorry that I'm not good at English writing because I'm a student in a non-English speaking country.
kzzang3831 is offline   Reply With Quote
Old   September 12, 2024, 05:18
Gert-Jan
Gert-Jan will become famous soon enough
The impeller is rotating in reality. Therefore you need to put it in a rotating domain. Why do you want to ignore that in a proper CFD analysis? What is your goal of your CFD analysis?
kzzang3831 likes this.
Gert-Jan is offline   Reply With Quote
Old   September 12, 2024, 05:51
Jang Geonwoo
If I give the condition to rotate only the blades of the propeller, and I don't set the rotating domain, would I get a wrong calculation result?
So far, I have only given moving mesh conditions to propeller blades without setting the rotating domain. And no successful results.
Old   September 12, 2024, 06:00
Gert-Jan
That is not how it is going to work. Results will be wrong.
Also, to get accurate results, you need to run transient cases. There is no other option than to let the domain rotate and set an interface (Transient-rotor-stator interaction) where the domains meet.
Old   September 12, 2024, 10:58
Jang Geonwoo
I'll try again based on the feedback you mentioned! Thank you so much for your advice.
Old   September 12, 2024, 13:12
Erik
evcelica is on a distinguished road
Think about it, and how the solver is working.
If only your blades spin as you say, what would your new mesh look like?
Wouldn't it have to re-mesh every time they rotated to any different angle than original?
So why not instead just rotate that surrounding mesh with the blades and just have a single, rotating mesh region. Then an interface is used between the rotating and non-rotating domain at their circumferential interface.
evcelica is offline   Reply With Quote
Old   September 13, 2024, 01:39
Jang Geonwoo
Hello
I don't think I specified a rotating domain in the tutorial link I attached. So I thought I didn't have to specify a rotating domain either. Is there anything I missed?
https://youtu.be/3Ig1kodreAg?si=A0e3N4pF_KzPowA4
Old   September 24, 2024, 10:13
Erik
That tutorial is of a gear pump which is using immersed solid, and those solids are using rotating domains. It is done like that because with two overlapping gears you can't do what you are able to do with your single impeller where you split the mesh into a single rotating domain and the non-rotating one. I guess you COULD perform your model the same way, but with your single impeller, you don't have to. I have no idea how the "immersed solids" actually works, but it is surely not as efficient or accurate as the conventional rotating domain methods you are able to perform with nonoverlapping single impellers.
Old   September 24, 2024, 11:02
Jang Geonwoo
I've only recently finally understood the difference between MRF and Dynamic mesh techniques, and the pros and cons of each technique. I've had a great realization thanks to the experts here.
Rotating Mesh - Mesh Overlap/Discontinuity At Boundary Interface sai95kamal FLUENT 1 June 15, 2020 09:58
FloEFD rotating region 310toumad FloEFD, FloWorks & FloTHERM 4 September 11, 2019 10:28
Problems with rotating machinery (Centrifugal Pump) in FLUENT RR2 FLUENT 1 January 17, 2016 06:23
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
Combine non rotating part with rotating parts or not ? teck0516 Main CFD Forum 0 July 16, 2011 14:38
