[Workbench] Error structured mesh for an airfoil |
July 2, 2024, 08:36 |
Daniel Larrondo
Rep Power: 2 |
Hi, im currently learning CFD and i have some trouble meshing airfoil with significant chamber. I have followed some tutorials and made some good meshes, but now im doing a mesh for NACA6411 and i have this (picture: https://files.fm/u/xnwzngchgh ).
Help please, im not having the result i want. Thanks!! |
July 2, 2024, 10:23 |
Eduardo
Your bias factor on some of your Edge Sizings is set up in the wrong direction. Zoom in and make sure you're using the right type of Bias Factor, and that it is set up in the proper direction, towards the airfoil.
July 2, 2024, 11:17 |
Daniel Larrondo
Rep Power: 2 |
That is the problem, i revised all the bias from all sizings and more, and seems correct.
#airfoil, #mesh #ansys #fluent |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 15:16 |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 12:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Parameters of a good airfoil mesh | CharlieBra7o | Mesh Generation & Pre-Processing | 4 | November 20, 2018 14:42 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
