[ICEM] Problem with meshing edges of a diamond airfoil |
QC
Rep Power: 7 ![]() |
Hello all,
I am preparing mesh for 5 blades with diamond airfoil. I have five 3D blades with the same shape, same setting, and ..... All parameters are the same. I generated the mesh. As the attached image shows, the mesh is not the same for them. to force the ICEM to follow the edge, I used curvature proximity-based. But it seems ICEM is not following the edge. Do you know: 1- Why the mesh is not the same? 2- How can I force ICEM to generate mesh like the right blade? How to force it to follow the edge geometry? Thanks |
Gert-Jan
Rep Power: 27 ![]() |
1) Make sure your geometry not only contains surfaces, but also contains curves
2) Define Thin Cuts. You can find them here on forum, or in the Help. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
[ANSYS Meshing] problem about the geometry and meshing of the airfoil | yileihe1989 | ANSYS Meshing & Geometry | 2 | February 24, 2013 06:18 |
