[TurboGrid] PyTurbogrid NDF File Format
Like Tree1Likes
  • 1 Post By kaboka
Old   May 6, 2024, 07:32
Default PyTurbogrid NDF File Format
Daniel
zacko is on a distinguished road
I am currently trying to dig into PyAnsys, especially PyTurbogrid.
Currently, the API does not support direct import of the usual .curve files.
It will be implicitly stated in an .inf file.
But, loading the curve files through an .inf file, limitations of the API are present.
Therefore, I would need to use the Multi_blade_row API, which needs an NDF file.
I looked everywhere, but nowhere is a good explanation how this file should look for Turbogrid, in order to specify my .curve files or other blade parameters.
Has anyone an example file or any hints how I could create such an .NDF file?
Thank you and kind regards
Daniel
zacko is offline   Reply With Quote
Old   July 25, 2024, 07:59
Kaboka
kaboka is on a distinguished road
Hello Daniel,
If you are generating your blade geometry in BladeGen or Blade Editor, you can import your blade geometry information in Design Modeler by using CAD Import => Write NDF: Blade CAD Import Files: feature.
The workflow is attached.
Best regards
Bora
zacko likes this.
kaboka is offline   Reply With Quote
Old   August 1, 2024, 21:13
Daniel
Hi Bora, thanks for the information.
I don't work in Bladegen , therefore I was looking if there would be a manual way of putting my already existing coordinates into that format for pyTurbogrid. But, might be not possible.
Maybe they add a proper method for the standard curve files in the future.
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
