[ANSYS Meshing] Fluent watertight mesh quad surface cells.
Like Tree1Likes
  • 1 Post By siw
Old   March 16, 2024, 09:17
Default Fluent watertight mesh quad surface cells.
Karem Elmahalawy
Karem is on a distinguished road
Hello guys,
When generating the surface mesh in fluent meshing, the surface cells are automatically set to triangles while i need them to be quadrilaterals. The volume mesh is "Hexcore" and I need no transition region between the core and surface so i need both surface and core of "4 corner" type cells.
Thanks.
https://im.ge/i/Triangle-Surface-wit...-Volume.R6ycWm
Karem is offline   Reply With Quote
Old   March 26, 2024, 02:23
Default Re
Jamie Cordeiro
JamieC1 is on a distinguished road
I have a suggestion that will help you to solve this issue. To get square cells on the surface in Fluent, you can do these things: Publix Passport
  1. Look for an option to make the surface mesh squares instead of triangles.
  2. If the mesh is triangles, you might need to change it to squares yourself.
  3. Look for help on forums from others who use Fluent.
Always check the Fluent guide for the best way to do this.
I hope my suggestion will be helpful for everyone.
Best regard,
Jamie
JamieC1 is offline   Reply With Quote
Old   March 26, 2024, 10:34
siw
Stuart
siw will become famous soon enough
I recommend you watch this Ansys Innovation Course for Surface Mesh Generation in Fluent Meshing (Watertight Work Flow): https://courses.ansys.com/index.php/...-surface-mesh/
BTW, you have titled this thread with [ANSYS Meshing]. ANSYS Meshing and Fluent Meshing are different applications.
SphericalCube likes this.
siw is offline   Reply With Quote
flow over cylinder in openFoam saeed jamshidi OpenFOAM Pre-Processing 3 August 11, 2023 16:16
[snappyHexMesh] sHM too many cells Knapsack OpenFOAM Meshing & Mesh Conversion 2 July 8, 2017 08:41
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
