[ICEM] Unable to generate prism mesh due to unfamiliar error |
November 27, 2023, 05:31 |
Vinayak Gautam
Can somebody please tell me what is the cause of this error. I've been trying to create prism from the bottom of an empty computational domain in ICEM and I've followed all the necessary steps prior to prism generation, i.e., Surface mesh creation, its smoothing, Volume mesh creation, its smoothing but for some reason it just won't create prisms and the error message it is giving, I have no clue whatsoever what it is ! Someone please help. I've tried a lot many mesh sizings but to no avail. The error message is as follows: Done saving tetin file. Writing domain "temp_prism0.uns" ... Done saving domain file. Running: "C:/Program Files/ANSYS Inc/v202/icemcfd/win64_amd/icemcfd/prism" D:/Aubaid Program is running: pid = 16324 ANSYS ICEM CFD Prism compiled on 6/1/2020 at 3:25 p.m. running on Windows (64 bit version) (c) Copyright 1991 - 2020 Ansys Inc. Usage: àq2 filename error executing command: surface_file error parsing input file D:/Aubaid Application is finished. Error: prism terminated prematurely --- Mesh Info --- Element types : NODE : 8 LINE_2 : 637 TETRA_4 : 196911 TRI_3 : 27230 Element parts : BOTTOM : 11775 CREATED_MATERIAL_1 : 196911 INLET : 2289 OUTLET : 2280 SIDES : 8092 SOLID_1_1 : 645 TOP : 2794 Total elements : 224786 Total nodes : 40239 Min : -2.1 -2.05 0 Max : 6 2.05 2.4 Finished compute mesh FYI, the surface meshes that I create usually reach quality of around 0.56 after smoothing and the volume meshes that I generate after reach a quality of around 0.4 after smoothing. I'm hoping this isn't a issue as I have seen a number of tutors on youtube managing to create prisms with quality worse than me ! Many thanks for your help in advance. |
December 4, 2023, 16:38 |
Gert-Jan
Rep Power: 28 |
Given the meassage
Usage: àq2 filename I expect you have some uncommon characters in your file name. Please avoid any characters like " à " |
icem-cfd, prism mesh |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
