Rep Power: 3 ![]() |
I have a 3D STL wing that is open on both sides and not solid. In other words, it is like a shell. I want to convert it into a solid wing and take it to Design Modeler software to draw the domain and finally refer to ICEM software for meshing. How can I convert STL wing to solid wing ? Thanks in advance. |
Gert-Jan
Rep Power: 27 ![]() |
Designmodeler cannot handle stl very well.
Better try to import this directly in ICEM and try to create a closed volume by adding surfaces. Remember, in ICEM it is not necessary to have a 3D solid. A group of (overlapping) surfaces is enough to generate a bounded volume in which ICEM can generate a mesh. |
#3 | |
It would be great if I could directly open the wing STL file in ICEM and then mesh it. I opened the wing STL file in ICEM but the wing and domain lines were not selectable, as if the lines were locked.I want to use a structured mesh. How can I Mesh it ? Regards. |
Gert-Jan
Forget creating a structured mesh directly from a STL. Impossible. If you want this, then you need to reconstruct/redraw the geometry from the STL using Spaceclaim or ICEM.
#5 | |
I opened the STL file in ICEM, which is as follows, and all its lines are not selectable, as if they are locked. I posted the picture here, I don't know if it can be displayed for you. If it cannot be displayed, please tell me how to send the photo. Thankyou |
Gert-Jan
In the bottom of your screen, there is a button called Go Advanced. There you can add pictures.
I clicked the go-advance option and put the photo link from Google Drive, but apparently it still can't be displayed. I would be grateful if you could tell me how to send the photo in more detail
#9 |
Gert-Jan
Don't use external links. In the Go Advanced menu there is the paperclip icon allowing you to attached pictures to a thread directly.
#11 | |
File -> import geometry -> Faceted -> STL None of the lines displayed on the page can be selected. |
#12 |
Gert-Jan
Yes. But what do you expect me to do if you don't know how ICEM works.
Have you tried any tutorial? I'm a volunteer, not a help desk employee from ANSYS. Nevertheless, I think (I'm not sure!): - You have imported surfaces. Are these closed when you turn them on solid-view? - you want an extruded 2D mesh. If you have a surface, create lines and points, either automatically, or manually, then create a mesh on a symmetry surface and then extrude in 1 direction. It you don't have surfaces (you imported a faceted mesh, I guess), then manually create points & lines by clicking on the edges visible. Then create surfaces from the lines then a surface mesh end then extruide. Good luck. You might need it. |
#13 | |
There is no solid view for me to try. I don't have any surface and I think faceted mesh is entered. Now tell me more precisely how to create the lines and then draw the surfaces ? Thanks. |
#14 |
Gert-Jan
Your stl info is apparently useless. I would never use or ask for stl formats. They're the worst. Everything is better. Ask for igs, step or parasolid.
Now you need to click on the screen to create points, connect these to make a line, and create a surface between two lines. Just use the stl as guideline where to click on thhe screen. All in the Geometry menu. The required Icons are already present in the image you shared. From this geometry you should create the blocking, but you are already familiar with that apparently. |
#15 | |
Rep Power: 0 ![]() |
#16 |
#17 | |
[mesh manipulation] How to split stl file? | sunagra27 | OpenFOAM Meshing & Mesh Conversion | 5 | March 18, 2021 11:00 |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[ICEM] STL file! How is it useful? | bidi | ANSYS Meshing & Geometry | 0 | December 26, 2016 21:33 |
[ICEM] Work with imported STL geometry | KateEisenhower | ANSYS Meshing & Geometry | 2 | July 9, 2015 10:46 |
[snappyHexMesh] Experimentally obtained STL file for internal Flow SnappyHexMesh | Irish09 | OpenFOAM Meshing & Mesh Conversion | 9 | April 7, 2012 08:50 |
