January 6, 2023, 04:34 |
ICEM meshing trouble shooting.
MANU P ANAND
Rep Power: 12 |
I had attached the figure of geometry. I had specified all the boundaries according to the figure. After meshing, I load the mesh on fluent, the wall is not fully available. Why?
January 6, 2023, 06:52 |
Gert-Jan
Rep Power: 28 |
In ICEM, if you show the mesh, do you see elements on this internal wall?
January 7, 2023, 02:39 |
MANU P ANAND
Rep Power: 12 |
Thank you for reply, yes mesh is available in whole domain, but wall boundary is missing.
January 8, 2023, 10:13 |
Gert-Jan
Rep Power: 28 |
Provided, the wall is a thin surface, then you forgot to set it as Internal wall or as Split wall.
You should set this using the Second Icon of Mesh setup were you also set inflation. The difference between internal and split wall is that with internal wall, the mesh is conformal on both sides of the wall. Using Split wall, you will have different mesh on both sides. With conformal wall, you have the possibility in Fluent to define a wall or an interface. With Split wall, you can only make it a wall. |
January 9, 2023, 03:16 |
#5 | |
MANU P ANAND
Rep Power: 12 |
January 9, 2023, 04:08 |
Gert-Jan
Rep Power: 28 |
It can be anything.......
- you say it doesn't work? Where? In ICEM or in Fluent? Please be clear if you want help. I cannot read your mind. - Are you sure it is a thin wall? Do you know what this means/implies? Can you show your geometry in ICEM? - After meshing, do you see elements on the thin wall? |
January 9, 2023, 20:23 |
MANU P ANAND
Rep Power: 12 |
I am attaching the pictures of mesh. I am not an expert in this, i tried to specify split wall to all after I didn't get the expected result on interior wall
January 10, 2023, 03:04 |
MANU P ANAND
Rep Power: 12 |
Thank you for your support through the reply, I had solved it, now. the problem was the geometry file has two surface in same interior wall. I removed these walls and created new wall with split walls which solved my problem.
boundary error, icem, meshing |
[ICEM] ICEM Meshing Beginner facing problem importing file. | rrahman | ANSYS Meshing & Geometry | 0 | September 2, 2015 15:18 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 12:27 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 11:09 |
ICEM meshing question | gsbhatia89 | ANSYS Meshing & Geometry | 5 | June 14, 2010 09:24 |
