Rep Power: 4 ![]() |
Hello everyone,
I'm trying to make a simple hexa mesh for a sharp trailing edge wing. I have created a c grid and set the appropriate values. However, I get two edges (right next to the wing tip trailing edge) with very bad quality hexas. Trailng edge with bad elements.png If the BLk and Tin files are needed please let me know how i can contact you and I will be happy to send it, I get a error when i try to upload the zip file here. Thank you in advance! |
Stuart
Rep Power: 25 ![]() |
If you have not already watched them, then I recommend you (and most other ICEM CFD Users) watch this 3-part YouTube series by ANSYS:
https://www.youtube.com/watch?v=tYrbScUH9RE https://www.youtube.com/watch?v=EknKVAJGEJ8 https://www.youtube.com/watch?v=6wQPeBpvwCk Can the mods update the ANSYS Meshing & Geometry wiki/FAQs with these three videos by ANSYS (PSYMN). |
Chrowale
You need to transform the block in the wing and adjacent span-wise to Y-block. unfortunately ,in my experience you cannot use the O-Grid with Y-block method.
icemwing, mesh wing hexa |
[ICEM] Low quality tetra mesh at sharp edge | CFXer | ANSYS Meshing & Geometry | 1 | September 2, 2020 07:39 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] ICEM Hexa meshing tutorial - Wing with sharp trailing edge | Far | ANSYS Meshing & Geometry | 34 | October 21, 2013 05:46 |
[ICEM] ICEM Hexa meshing tutorial - Wing with sharp trailing edge | Far | ANSYS Meshing & Geometry | 0 | May 18, 2012 14:20 |
ICEM Hexa meshing tutorial - Wing with sharp trailing edge | Far | ANSYS | 1 | May 18, 2012 14:19 |
