[ANSYS Meshing] Non-conformal mesh between fluid zone without interface
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   July 29, 2022, 06:49
Default Non-conformal mesh between fluid zone without interface
Justin_li is on a distinguished road
Hello everyone,
I am doing a simulation of which only a small area is important. To avoid too many cells or large aspect ratio. I would like to generate a non-conformal mesh.
I have a try using designModeler to build a test case(2d case of 2 rectangular) and form it into 2 bodies. Thus I can define the grid number at edge of each rectangular in meshing. I did it and defined an interface of matching before calculating it in fluent, but seems the result will be a little discontinuity at the non-conformal boundary.
I actually have a case file which is also using non-conformal mesh even including 2 interface there. But from the boundary I could not see there are any interface. And from the results I could not see any discontinuity. I am really confused how they did it. And I believe it could be a better way since if I have multi non conformal interface, the interface definition could be troublesome!
I checked the threads related and found that it seems we have to define an interface between non-conformal mesh in fluent.
So, I am wondering if anyone knows how that can be done? Like just treat the non-conformal interface as interior since it is all fluid. Any comments will be highly appreciated! Thanks in advance!
Justin_li is offline   Reply With Quote
Old   July 30, 2022, 03:31
Gert-Jan
Gert-Jan will become famous soon enough
Shouldn't you use Fluent Meshing here with Cutcell-mesh-approach, with hanging nodes?
Justin_li likes this.
Gert-Jan is offline   Reply With Quote
Old   July 30, 2022, 04:06
Hello Jan! Thanks for your reply! Did you mean the adapt mesh in fluent right? I think I solved it!
I am so confused before like with no interface how they did it. Now it is clear! Fluent can adapt to refine structure mesh after you give a base structure mesh and then choose region you wanna to refine and click adapt!
Thanks for your help!
Old   July 30, 2022, 04:23
Gert-Jan
No, that is not what I mean. In the latest versions of Fluent, there is a new meshing GUI, called fluent meshing. There you can generate your mesh as well, instead of ANSYS-meshing.
This fluent meshing allows you to create meshes based on cut-cell-technology, and that is more ore less what you desire, if I look to your non-corformal meshes in Post.
Nevertheless, if fluent can adapt your currnet ANSYS-meshing mesh to something what you want, then that is fine as well.
Old   July 30, 2022, 09:19
Hello Jan, I see. Sounds great! The refinement I need just like cut cell. I think I will try fluent meshing next time. Before I think out of no way. Now there are two solutions. Cool! Thanks again!
ansys, mesh, non-conformal interface, non-conformal mesh
Illegal cell label -1, fluent3DMeshToFoam BenGher OpenFOAM 7 October 10, 2023 01:02
Ansys Error: Unassigned interface zone detected Souma ANSYS 0 October 20, 2020 06:15
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
