[ICEM] Removing extra faces generated while splitting block
Like Tree1Likes
  • 1 Post By Nima Shah
Old   April 11, 2022, 16:25
Default Removing extra faces generated while splitting block
Nima
Nima Shah is on a distinguished road
Hi all,
I want to mesh a venturi tube with ICEM with sweep 3d blocking. While splitting the main block and removing the extras, some unwanted faces are generated. How can I remove those, because this results in some edges that will remain unassociated?
Best
Nima Shah is offline   Reply With Quote
Old   April 13, 2022, 17:28
Kira
aero_head is on a distinguished road
I think it is just a matter of refining your blocking strategy.
Maybe split the block horizontally before the two vertical splits, and instead of splitting all blocks, just select the one above the horizontal split.
aero_head is offline   Reply With Quote
Old   April 13, 2022, 19:50
Nima
Thanks, dear aero-head. I solved it as you mentioned.
aero_head likes this.
icem, meshing, sweep mesh
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 12:28
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
