[ICEM] Mesh Is Not Following Trailing Edge Curve Correctly |
February 8, 2022, 15:24 |
Rep Power: 4 |
Hi all,
I am currently trying to analyze a propeller in ICEM CFD. Everything was OK until meshing is done. As you can see in the trailing edge of the wing, the mesh elements are pretty low quality and even don't follow the geometry curve. I tried everything to solve it. Any Idea how to solve? Any solution will help. Thanks! Picture: Screenshot_20220209-031953_AnyDesk.jpg |
February 9, 2022, 06:51 |
Gert-Jan
Rep Power: 28 |
Are you sure a curve is present at the small edge? Or do you only have surfaces?
Anyway, best is to go to the menu: Global Mesh Setup > Define thin cuts There you can tell ICEM to pay attention to the edge of your geometry. For additional help on this menu, I refer to this query: trouble with small angles |
icem, mrf, propeller, trailing edge |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[ICEM] Blunt Trailing Edge Mesh | jasonbot | ANSYS Meshing & Geometry | 8 | March 10, 2020 02:58 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[GAMBIT] Trailing edge mesh problem | Bharatt | ANSYS Meshing & Geometry | 11 | June 30, 2012 00:57 |
