[Other] [Spaceclaim] Curvature awkward - display or geometry error? |
Kirsten Braun
Rep Power: 10 ![]() |
Hi everyone,
very basic question (I'm new to Spaceclaim): does Spaceclaim display curvature in an angular fashion or did I make some error? I highlighted some awkward shapes in the image below. The surface bit is of approx. 0.3 mm depth and was generated in Spaceclaim using "Blend" between the edge loops. The left edge loop was generated using "Sketch"-> "Circle" (then extrusion to the left), everything on the right was imported (.step). When moving on to meshing, it looks similarly angular and I get a meshing error, so just wondering, if the error could be caused by this awkward curvature. Thanks! K |
Gert-Jan
Rep Power: 27 ![]() |
In my experience it is just a display error.
However, my experience is also that sometimes meshing goes better if you cut surfaces that span 360°, into sections of 180° or 90°. Additionally the display in spaceclaim improves as well. |
Kirsten Braun
Thanks, Gert-Jan! Helpful hint; I didn't know that.
curvature, display, spaceclaim |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
