October 28, 2021, 12:36 |
How to Non-conformal mesh
Mohammad Shafiee
Rep Power: 7 |
Hello, I'm trying to generate a good quality hexahedral mesh for a relatively simple but large domain shown in the image below using the ICEM CFD:
dom.jpg The problem is that I need a really fine grid near the cubes and If I use a conformal mesh, number of cells within the entire domain will be much higher than i can handle. So I'm wondering if there is any way to make a structured non-conformal mesh for my problem using ICEM CFD. Something like the picture below: grid.png I've had this problem for a while now so any help would be much appreciated Thanks. P.S. I'm pretty new to ICEM and couldn't find my answer elsewhere, but I have been using GAMBIT for mesh generation for quite sometime. |
November 1, 2021, 07:53 |
Gert-Jan
Rep Power: 28 |
What you show is a Cutcell-type of mesh. You cannot generate this using ICEM.
Within ANSYS, you can only generate this type of mesh using the mesher inside Fluent. Also, you can only use this mesh in Fluent. CFX won't eat it because of so-called hanging nodes. |
non conformal mesh |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[ICEM] Making conformal mesh at interface for MRF simulation. | afreis | ANSYS Meshing & Geometry | 1 | February 4, 2022 11:14 |
[ANSYS Meshing] Relation between conformal mesh and mesh connexions in Ansys meshing | Manel | ANSYS Meshing & Geometry | 0 | December 26, 2019 14:16 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
