[ANSYS Meshing] Hello how to get conformal mesh in Ansys meshing withou using Spaceclaim or DM
Like Tree1Likes
  • 1 Post By siw
Old   August 5, 2021, 04:45
Default Hello how to get conformal mesh in Ansys meshing withou using Spaceclaim or DM
Mandeep Shetty
granzer is on a distinguished road
Hello is there a way to hve confirmal mesh between 2 bodies which are touching each other without using the "shared-topology" options from space claim or Design modeler.i.e. is there a way to set 2 bodies as "shared-topology" in Ansys meshing it self?
granzer is offline   Reply With Quote
Old   August 5, 2021, 05:05
Mandeep Shetty
Can we use Connection->Insert->Contact group for this ? Ia there any other way?
Old   August 5, 2021, 06:22
siw
Stuart
siw will become famous soon enough
Checking the ANSYS Meshing 2021 R2 User Guide (see section Meshing: Capabilities in Ansys Workbench / Conformal and Non-Conformal Meshing) and it recommends Shared Topology in SpaceClaim or DesignModeler. However, there is also the option to use Assembly Meshing, Mesh Connection (for shell bodies) and Node Merge, also explained in the User Guide.
granzer likes this.
siw is offline   Reply With Quote
shared topology
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
ANSYS Meshing: Create Conformal Interface emspinosa ANSYS Meshing & Geometry 17 March 2, 2023 04:56
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
How To save a created mesh file in Ansys Meshing ashtonJ CFX 4 January 7, 2012 23:04
[Other] Ansys meshing - periodic mesh for fluent jsm ANSYS Meshing & Geometry 4 September 24, 2010 15:25
