August 2, 2021, 16:00 |
3D pipe hex mesh aspect ratio 1
Lolita
Rep Power: 10 |
I am meshing a 3D pipe having length 200 mm and diameter 25 mm. I will be using this mesh for multiphase flow using VOF, hence i wish to have a aspect ratio close to 1 since it gives the best result. I have attached all the figures 1.png, 2.png,Attachment 85723 As you can see in the figures, min aspect ration is 1.324.png and maximum aspect ratio of 2.813.png, also you can find the regions of trouble in figures. I have used O-grid mesh and modified it with an offset value of 0.5. All the number of divisions of various edges are shown here in this figure 9.png. I have also given a spacing 1 of 1 mm with Ratio 1 equals to 1.1. Any help would be highly appreciated regards |
August 3, 2021, 04:10 |
Lolita
Rep Power: 10 |
I played around with the number of divisions and O-grid offset, removed the boundary layers at the wall and now the min aspect ratio is 1 and a max of 1.6610.png. Is there any guideline/tips/algorithm to get the aspect ratio close to 1 based on the dimension of the cylinder.
regards |
August 3, 2021, 19:51 |
Alain Islas
Rep Power: 7 |
Personally, I don't see any problem in having cells with aspect ratio >1, especially at the near wall region. Depending on your y+ values, you'll find it inevitable. It is common practice to have aspect ratios 5-10 (sometimes even more).
CFD solvers are more sensitive to non-orthogonal qualities, min angle, skewness and/or determinants. |
August 4, 2021, 05:03 |
#4 | |
Lolita
Rep Power: 10 |
August 31, 2021, 15:55 |
Henrique Stel
Rep Power: 17 |
It is virtually impossible to get a perfect 1.0 aspect ratio for all elements using an O-Grid strategy. A range within 1-3 is pretty OK though, even for VOF. Eventually, a mesh sensitivity test will let you know if the resulting grid is OK for your purposes.
maximum aspect ratio of mesh | Weiqiang Liu | FLUENT | 4 | June 3, 2020 11:04 |
[OpenFOAM] Error !! No. of points and fields don't match | mkjmalik | ParaView | 4 | November 2, 2019 11:37 |
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from | syntex | OpenFOAM Meshing & Mesh Conversion | 19 | December 10, 2018 08:21 |
[blockMesh] pipe bend mesh imperfect | jochemvandenbosch | OpenFOAM Meshing & Mesh Conversion | 9 | November 12, 2014 05:49 |
Aspect ratio in orthogonal mesh | bmikuz | Mesh Generation & Pre-Processing | 0 | June 14, 2014 11:33 |
