[ICEM] ICEM 4 O-grids for 4 Cylinder inside a domain |
April 16, 2021, 07:34 |
ANGELO
Rep Power: 6 |
Hi everyone,
I have been working on Icem for almost one year. Currently, I am meshing a geometry which consists of a cylinder with two plates on both sides of it separated by a gap(between the cylinder and each plate). The whole cylinder and the plates are then immersed in a fluid domain covering everything. I want to mesh the fluid domain around the cylinder, the gap and the plates. I need at least 3 O-grids(one for the cylinder, one for the gap and one for the plates). The problem is that when I create each O-grid using the two faces on the top and the bottom surfaces of the fluid domain, the 3 O-grids traverse the whole domain ending up by affecting the whole domain.(See the figures whene the 3 O-grids are affecting the top and the bottom Surfaces of the fluid domain). I want to ask if there is a way to create each O-grid for each block of the cylinder, the plates and the gap without selecting each time the blocks from top to bottom especially that there is only two faces (Top and bottom). I would really appreciate your help. Its been two weeks trying to have a clear mesh but I couldnt. Thank you in advance, Angelo |
April 16, 2021, 10:02 |
Sebastian Engel
Rep Power: 21 |
Asking for clarification: the green and blue parts are plates with a non-zero thickness (so not part of the domain)?
And the mesh between the plates should be somewhat independent from the mesh at the far sides of the plates? |
April 16, 2021, 10:15 |
ANGELO
Rep Power: 6 |
The plates have thickness of 8 mm and between the plates and the cylinder there is also a gap of 2mm. I am trying to mesh the fluid around all parts(Cylinder, plates, gap). I tried with 3 O-grids from top to bottom and then associate each one to the cylinder, gap and the plates, respectively but seems not good since its affecting everything. See figures for clarification.
Thank you in advance, |
April 16, 2021, 14:40 |
Sebastian Engel
Rep Power: 21 |
I assume you deleted the blocks filling the plates. Moreover, i believe that you might not have deleted the respective blocks permanently.
By not deleting a block permanently, it is moved into the part VORFN, which is a part which collect blocks outside of the domain. This moving-only means the adjacent blocks are kept related. So if you add an ogrid between the plates, the blocks still connected via the "deleted" block will receive the same treatment. This might be what you are experiencing. To stop this relation you must delete the the blocks in the plates to separate the free fluid domains on the far sides. If my assumption is correct, the respective blocks are still present in your VORFN part. Delete the respective blocks again, but now permanently. |
April 16, 2021, 16:08 |
ANGELO
Rep Power: 6 |
I deleted the block from inside the plates as well as inside the cylinder. But my problem is that the 3 O-grids are seen on the top surface of the fluid domain as you can see the image. Is it good to select all middle blocks each time I want to create an ogrid or there is another way to select each block representing the part that I want to have an O-grid on it. The problem is that no faces in between the parts so I am forced each time to select the blocks from top to bottom with the faces(Top and bottom). Plz See the figure of the blocking.
Thank you for your help. |
April 16, 2021, 17:16 |
#6 | |||
Sebastian Engel
Rep Power: 21 |
Then inspect the VORFN part whether it looks like a huge o-grid around your domain, or whether the "outside" is still connected to the "inside". Quote:
If you want an axial-only o-grid (4 blocks) in a selected block, then you have to select the faces which should not be extruded. There is no way around this. How should the programm know what you want to do? Although there are a lot of advancements made with machine learning, icem will likely not profit from it at all (due to ansys' strategy). |
Periodic Pressure drop | cfd_begin | CFX | 10 | May 25, 2017 08:09 |
[ICEM] interface between rotating and stationery domain in icem mesh | mohamed samy | ANSYS Meshing & Geometry | 0 | May 16, 2017 13:27 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Air natural convection inside a vertical cylinder | Pavolo | FLUENT | 3 | December 12, 2012 07:00 |
