[ANSYS Meshing] Meshing solid body with pipes
Like Tree2Likes
  • 2 Post By evcelica
Old   March 10, 2021, 14:57
Default Meshing solid body with pipes
Valaki Valami
woodwax is on a distinguished road
Is there any suggestion on how I can mesh this solid body?
I tried multizone hexa mesh but I get an error: "MultiZone found free block in swept body."
I would like to have a nice hexa mesh.
In the last picture, you can see the counterpart (the water) meshed in hexa.
woodwax is offline   Reply With Quote
Old   March 10, 2021, 18:41
Erik
evcelica is on a distinguished road
Honestly, having a nice hexa mesh on the solid body is not that important. It is just 1 degree of freedom for heat transfer through the solid; mesh quality is nowhere near as important as it is for fluids.
Did you try hex dominant method if you are set on hexas?
I normally make the two bodies a multibody part so that the mesh is conformal across the interface, which probably makes a bigger difference than mesh quality of the solid body.
woodwax and aero_head like this.
evcelica is offline   Reply With Quote
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
[ANSYS Meshing] Use solid body of influence while suppressing mesh brian_troyer ANSYS Meshing & Geometry 1 March 2, 2020 03:16
Rigid body in creeping flow - COMSOL MultiPhy CFD Freelancers 1 June 8, 2017 02:38
how to move a solid body along a clear line m.r_khani FLUENT 0 November 26, 2011 08:04
Meshing 3D Body mahadevan.swamy Main CFD Forum 1 June 23, 2009 11:13
