January 24, 2021, 16:09 |
How to Coarsen Mesh in Selected Block
Kira
Rep Power: 8 |
Hello Everyone,
I am trying to coarsen the mesh in a selected block. The ICEM manual tells me I can: Use Blocking > Pre-Mesh Params > Refinement to refine or coarsen the mesh. You can apply the refinement/coarsening in all three major directions simultaneously or in just one major direction. Refinement To refine the mesh, enter a scale factor greater than 1. Coarsening To coarsen the mesh, enter a scale factor less than 1. I go to the refinement option and enter a scale factor less than 1 (see screenshot where I used 0.5), but it gives me an error and tells me that the factor must be positive. Am I missing something? Thanks in advance |
January 24, 2021, 16:15 |
Kira
Rep Power: 8 |
I have found a solution.
I input 1/2 rather than 0.5 and it worked. Edit: it seems to not like when I use a factor of 1/3 and gives me warnings as attached. What do they mean? I am able to use 3X refinement in the opposite direction. Last edited by aero_head; January 24, 2021 at 16:32. Reason: ran into another problem |
January 25, 2021, 05:59 |
Rep Power: 18 |
That is just warning to hanging elements. Refinement "1/2" is for Fluent mesh. An "1/3" refinement is for CFX mesh. Look in Help on subsequent command "Edit Mesh > Merge Nodes > Merge Meshes".
January 25, 2021, 11:13 |
Kira
Rep Power: 8 |
Hello Ludvik,
Thanks for your reply. I do intend to use the mesh in CFX. When I go through with the 1/3 refinement, the program actually closes on me, saying there is a segmentation violation. Would this still be due to the hanging nodes? If I use 'Resolve Refinements', would that warning not appear? |
January 26, 2021, 01:45 |
Rep Power: 18 |
The mesh refinement in Blocking really produce uncorrect mesh for CFX.
Switch Premesh to Unstructured Mesh and use tool "Merge Mesh, Method: Resolve Refinements" to solve this. |
January 26, 2021, 21:19 |
Kira
Rep Power: 8 |
Could you please describe what you meant when you said the mesh it would produce would be incorrect? |
January 27, 2021, 04:04 |
Rep Power: 18 |
Word "incorrect" isn't exact, better is "impractical". In a model are too many Mesh Interfaces, who consumes time for creating model, computational time, .. .
January 27, 2021, 09:41 |
Kira
Rep Power: 8 |
Hello Ludvik,
Thank you for the additional information/clarification |
coarsen grid, icem, mesh, refinement |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
GeometricField -> mesh() Function | Tobi | OpenFOAM Programming & Development | 10 | November 19, 2020 11:33 |
[ICEM] Replay not working properly - Creating the mesh for Free Block. | Wingman | ANSYS Meshing & Geometry | 4 | January 17, 2017 03:57 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
