[ANSYS Meshing] The Quad Mesher Failed on one or more faces. (Ansys-Meshing Warning) |
November 16, 2020, 07:53 |
Andrew
Rep Power: 9 |
I am trying to get a structured 2D mesh (using face meshing) for a square cylinder in a rectangular domain. I am using the Number of Divisions (on edges) with Bias. I need to make the mesh fine at the cylinder walls. As I mesh the geometry I get the error:
I noticed that as I made the mesh finer, the mesh suddenly became unstructured. I could solve this by decreasing the Mesh Element Size by editing the Element Size setting after selecting Mesh from the Project Tree. As I continue meshing even this method doesn't work and I get the following error: "The Quad Mesher failed on one or more faces." and "Quad map meshing failed on one or more surfaces. A surface could be narrow with many boundary edges which may not have paired up for meshing. Using hard size controls on the boundary edges to force the same number of divisions might help. What I have tried: I tried decreasing the element size in hopes that it would work but it didn't For the divisions, I have set the behavior setting to hard and still it doesn't work. If I suppress all edge sidings I have specified and mesh them individually it works and there is no error. But the moment I un-suppress all the edge sizing and update the mesh, the mesh becomes unstructured. I have also tried assigning individual faces to separate Face Meshing just in case but that didn't help either. I would appreciate any insights on this one. It's for my project. I am also attaching the screenshots for the mesh. Please let me know if any other info is required to solve this issue. I would really appreciate your help and time. Thanks. |
November 16, 2020, 22:55 |
Andrew
Rep Power: 9 |
If anyone has had the same problem, then this is for them. I was able to solve this issue by:
1. Change the Physics preference to CFD and Solver Preference to Fluent (I wanted to use Fluent). [Just a recommendation, depends on which solver you are using and what analysis you will be doing] 2. Apply edge sizing to all the edges and then update the mesh. This worked for me. |
August 2, 2021, 23:58 |
#3 | |
hanheihei
ansys fluent 19.1, meshing 2d, warning message |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
