[ICEM] Change the grid size at the trailing edge of airfoil |
August 21, 2020, 21:12 |
Rep Power: 8 |
I used blocks to have a structured C-Type mesh for an airfoil. But now I have a problem. I need Y+ to be less than 1 on the first layer of boundary layer and this makes the first layer over the airfoil very thin, but this thin layer also goes after the trailing edge where the velocities are HIGH and this causes a high CFL number there. I just want the thin boundary layer mesh to be only around the airfoil and not after the trailing edge. I want the trailing edge mesh gets coarser (The area is shown in the image below). How can I do that? Thank you in advance. |
August 21, 2020, 21:44 |
#2 | |
Henrique Stel
Rep Power: 17 |
Good luck! |
December 27, 2020, 03:51 |
Kira
Rep Power: 9 |
Another method I think you could try is making a Y-grid with a 1/4 O-grid, as in the videos: http://www.youtube.com/watch?v=tYrbS...3&feature=plcp |
August 18, 2022, 17:08 |
Sandro Brad Martinez Sardon
Rep Power: 5 |
Hello aero_head,
Could you please update the youtube link because the video is down. Otherwise I am not able to erase that clustering in the trailing edge following the video. In case that you know alternatives to erase that clustering, please let me know. I would be pleased to hear your proposals. Thanks in advance. |
airfoil, ansys, icem, mesh |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 04:33 |
Large cells at trailing edge (airfoil) | AlphaDelta | STAR-CCM+ | 7 | April 11, 2020 09:29 |
[ANSYS Meshing] 3D Airfoil with Sharp Trailing Edge - Mesh Help | Toofanian | ANSYS Meshing & Geometry | 0 | August 8, 2016 20:54 |
airfoil trailing edge modelling in gambit | morteza08 | Main CFD Forum | 3 | June 4, 2010 14:36 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
