Ibrahim Rihani
Rep Power: 0 ![]() |
Dear all,
I am trying to make hexa mesh for the DTMB hull using ICEM CFD, for different case study, I will use FLUENT as solver, The main problem that I have a negative elements and the angel is zero, I tried make O grid in the stern check double vertices,no solution!! I did the main blocks and every thing seem to all right except those elements, I am trying since 6 months to find solution before I decide to post, I appreciate your help,if you have experience how to solve it or if you had same problem please share the solution with me. |
Sebastian Engel
Rep Power: 21 ![]() |
Could you share a quality histogram and some screenshots of the region with problems?
If there is a zero angle, there might be the chance that you squashed a block. Such block would have almost zero thickness, und would look like a thin layer when you display only blocks. |
Ibrahim Rihani
Thank you for your reply,
The bad elements area is near the bow here is below pic https://drive.google.com/file/d/1ZRG...ew?usp=sharing https://drive.google.com/file/d/1Zgd...ew?usp=sharing Last edited by Ibrahim_Rihani; August 4, 2020 at 13:28. Reason: inster links |
Sebastian Engel
You obviously know about scan planes. Investigate that region with bad elements further, and maybe share screenshots from a couple of different views.
Investigate how the respective blocks are formed. Why deviate they from the optimal cube shape. Which edges intersect others. |
fluent, hull, icem, mesh |
[ICEM] ICEM Meshing Beginner facing problem importing file. | rrahman | ANSYS Meshing & Geometry | 0 | September 2, 2015 14:18 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 30, 2015 23:10 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 11:27 |
[ANSYS Meshing] Hybrid meshing ICEM | djoul | ANSYS Meshing & Geometry | 2 | January 17, 2012 18:18 |
