gero
Rep Power: 6 ![]() |
Good morning everyone,
I have a minor problem with this mesh, how can I make a radial mesh (or o-ring mesh if you prefer)? Now the geometry is made of a single body which is the one you see in the pic. Should I divide it in more parts? Should I insert some kind of reference geometry? Thank you for your help in advance! L.G. |
Guven Nergiz
Hi L.G.,
You can odo this with biased infulation but people generally use multi-body geometries to create o-ring type (nice calling btw) meshes. "What i mean" I hope that ive understood you well. Best regards, Güven |
gero
Hi there,
I followed the two methods you suggested and I found out that the second gave better results. The inflation generated elements in the throat with a huge aspect ratio that gave me some problems during convergence. Thank you again, L.G. (thks for the o-ring but i actually read it somwhere else ![]() |
#4 | |
Guven Nergiz
Do not forget to like please ![]() Have a nice work. Best regards, Güven |
ansys, mesh 3d, nozzle simulation |
Convergent-Divergent Nozzle with MATLAB | Obad | Main CFD Forum | 8 | June 2, 2020 14:10 |
[ANSYS Meshing] Help about meshing well | berkmm | ANSYS Meshing & Geometry | 1 | May 11, 2020 15:32 |
Inverse Design Optimization | khavart | SU2 Shape Design | 0 | June 20, 2019 03:37 |
[ICEM] Meshing of pipes with a nozzle | nethmech | ANSYS Meshing & Geometry | 15 | December 24, 2013 12:58 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
