[ICEM] problems about face mesh missing elements |
June 20, 2020, 08:46 |
Rep Power: 6 |
Hi, I'm meshing for a 10-cell fuel cell stack, first I generate face mesh using blocks,then I can get the mesh in the middle by extruding mesh to form the 1-cell mesh and translating and coping mesh,and I need to get the mass flow of each stack.,so I create some iso-surfaces parallel to outlet,but I find there are some elements missing on the face and I'm confused. This will lead to inaccurate mass flow calculation.Does anyone know how it works?
June 22, 2020, 07:58 |
Rep Power: 6 |
solved,I think it's some of Fluent's bug,I tried today and it no longer occurs
June 22, 2020, 08:23 |
Gert-Jan
Rep Power: 28 |
I don't know if this helps, but when I see something like this in ICEM, mostly the problems are related to the normal of surface elements not being consistent. You can change this in the edit Mesh Menu > Reorient Mesh > Reorient consistent.
Just select one of the elements as a reference. It does not matter which one. In the end, at least all elements for each boundary have the same normal and are in one group in Fluent. |
June 22, 2020, 11:02 |
#4 | |
Rep Power: 6 |
still thanks for giving a idea. |
meshing, missing cells |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
