[ICEM] Blocking strategy - U tube inside a rectangle |
May 22, 2020, 21:12 |
sajjan
Rep Power: 10 |
I am trying to generate a hex-mesh for a u-tube contained inside a rectangle in ICEM. The problem statement is: fluid flows within the pipe which exchanges heat energy with the surroundings. If it was only a U-tube, I know the blocking strategy and how to mesh. But I am facing difficulty when it is contained inside the rectangular box. If possible, I do not want to mesh parts separately and merge them later. I wonder if anyone has gone through similar problem before or does have an idea about its blocking strategy. |
July 7, 2020, 05:13 |
sajjan
Gwenael H.
Rep Power: 20 |
Hello Sajjan,
If you already know how to do the meshing of the U-tube alone (simple Ogrid sweep) you can then add a second O-grid around the first one (select all the blocks in ICEM and then tick the "Around blocks" option). Then do some additional slicing / association to the outer rectangle and it should do the trick. Have fun |
blocking strategy, icem, tube and shell |
[ICEM] Blocking strategy for sharp angle junction (Pipe) | Daniel_Khazaei | ANSYS Meshing & Geometry | 6 | February 19, 2015 12:31 |
[ICEM] SAE Reference Notchback Model Blocking Strategy | Crank-Shaft | ANSYS Meshing & Geometry | 16 | January 27, 2015 23:10 |
How to create boundary layer using ICEM cfd and using blocking meshing strategy | costy | Main CFD Forum | 0 | April 12, 2014 05:14 |
[ICEM] Blocking topo for hexagonal tube with holes | siw | ANSYS Meshing & Geometry | 3 | February 10, 2012 15:17 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
