April 16, 2020, 13:58 |
Hex mesh with helical groove on pipe
Rep Power: 8 |
Hi all,
I am trying to hex mesh a periodic pipe unit, which has a helical groove running from inlet uptill outlet. That hasn't been successful so far. Any pointers on how can I achieve this would be great. |
February 2, 2021, 14:07 |
Kira
Rep Power: 9 |
I do not know if you have found a solution to this already, however I thought of this other thread when I saw your geometry: Icem for twist plate issue as I thought it was similar to what you are trying to do. I would try using the O-Grid technique as described there. Another option would be to do hybrid meshing or even unstructured meshing, if possible. |
helical groove, hex mesh, icem, periodic bc |
pimpleDyMFoam - rho not found | maasyraf3 | OpenFOAM Running, Solving & CFD | 10 | June 5, 2017 14:05 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[blockMesh] pipe bend mesh imperfect | jochemvandenbosch | OpenFOAM Meshing & Mesh Conversion | 9 | November 12, 2014 05:49 |
[Other] mergeMatchPairs with arcs | vainilreb | OpenFOAM Meshing & Mesh Conversion | 1 | August 5, 2013 09:11 |
[blockMesh] BlockMesh number internal faces and boundary | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | December 13, 2011 06:36 |
