[ANSYS Meshing] Creating a 2D Mesh with Ansys Workbench for OpenFOAM v1912 |
April 3, 2020, 01:25 |
Rep Power: 15 |
i am stuck with a problem and thought i would like to ask here in the OpenFOAM Sub-Forum instead of asking at the Ansys Meshing Forum. I want to create a 2D study in OpenFOAM. How do i mesh it with Ansys? There is no z-direction. As far as i understand for OpenFOAM 2D studies are 3D with one cell in z-direction (in my case its the z-direction). So I need a 3D body, since i have to name the faces for the boundary conditions. But how do i mesh with Ansys, I don't know how it can be done with Ansys Workbench. |
April 4, 2020, 09:59 |
#2 | |
The way to convert a fluent style mesh to OpenFOAM is : fluentMeshToFoam "name.msh" there is one for CFX mesh as well. OpenFOAM will automatically extrude it to three D (with one cell in Z) The extrusion width can then be found using the "checkMesh" utility, After that you can scale the Z extrusion to by using the command "transformPoints -scale "(X Y Z)" Beware that the extrusion will be done in +Z and -Z like "0.005 and -0.005" giving a total extrusion of 0.01 best |
[Workbench] Error creating mesh by using ANSYS workbench | newbie384 | ANSYS Meshing & Geometry | 7 | January 14, 2021 01:59 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[Workbench] Ansys Workbench mesh problem | engeagle | ANSYS Meshing & Geometry | 0 | March 21, 2016 11:22 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
