[ANSYS Meshing] one or more objects may have lost some scoping attachments during the geometry update |
March 12, 2020, 07:26 |
Raj
Rep Power: 6 |
Hello all,
I have pasted the error as my title. The full error is "One or more objects may have lost some scoping attachments during the geometry update. you can identify these tree objects by filtering the tree using the scoping option set to partial. The selective body meshing is not being recorded, so the meshing may not be persistent on an update. If you want to record the order of the body meshing, please use the Mesh Worksheet to track the meshing steps. Please see Selective Meshing documentation for more details." I was trying to refine the mesh because there was no convergence in my model in fluent. While I was trying to do it. The mesh is not letting me do it. I hope someone could help me! Thank you in advance Raj Last edited by Rajkool; March 12, 2020 at 07:31. Reason: Forgot to update full error |
March 13, 2020, 00:39 |
Svetlana Tkachenko
Rep Power: 15 |
Does ANSYS Mesh have any question marks in the tree under 'Mesh'?
March 13, 2020, 08:35 |
No Response in Mesh Tree
Raj
Rep Power: 6 |
No, there is only the "Update symbol" beside the mesh option. But after updating we get the same response with the errors and warnings.
May 10, 2020, 14:17 |
Elwin Heng
Rep Power: 6 |
Hi Raj have you found the solution to this problem?
August 13, 2020, 11:13 |
Shreyas Taware
I am also having the same problem in a counter flow heat exchanger
August 13, 2020, 11:46 |
Check Named Selection
Raj
Rep Power: 6 |
Just check the named selection is applied right and also check for the contacts in connections.
Even though the named selection is applied right, just apply it again. Some times workbench might be corrupted due to continious updates. In my case, the problem was solved by doing so. |
Update Geometry - swapping SolidWorks files | sanchezz | CFX | 7 | December 9, 2009 23:18 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 09:17 |
ICEM geometry update | Omar | CFX | 0 | July 4, 2007 16:55 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 05:31 |
Virtual/Real geometry. | Jack Keays | FLUENT | 9 | June 16, 2000 00:39 |
