February 23, 2020, 05:24 |
How make block
aref
Rep Power: 7 |
Hi
I just made a doughnut shape by revolving a circle around an axis in Solidworks( that is shown in the post) and i want mesh this solid in ICEM. i know that i should make two O-gird and split where i have 2 cross section,but i do not know how associate my block to my surface for rest places. i mean for 360 degree. |
February 23, 2020, 05:44 |
M
Rep Power: 13 |
Its trickier than I first thought. I will try it myself. Unfortunately I dont have ICEM at home to try right now ...
February 23, 2020, 12:12 |
aref
Rep Power: 7 |
Thank you dear AtoHM
i will wait for you to access your ICEM also i was intended to say that: I was trying to Simplification my main subject by posting that tube shape solid. but my main geometry is similar to previous problem but instead of a circle i used an airfoil an revolve it around an axis in solidworks and made a Cylindrical shape.(I show the picture in attachment).so do you have any idea how i can make a block that associate with my body. |
February 24, 2020, 02:11 |
M
Rep Power: 13 |
By the way you can always opt to only mesh a small part of the geometry and do the rotational extrusion / pattern in ICEM once you have the mesh for that part. That will be way easier than coming up with a blocking for the whole thing. Or you can mesh the 2D-section and extrude.
February 25, 2020, 08:38 |
Gert-Jan
Rep Power: 28 |
Indeed:
- Take the geometry of a cross section of the torus. - extrude this to a geometrical straight pipe - create a mesh in this straight pipe, either a tet/prism mesh or a hex mesh using an o-grid. - delete the mesh, except for the mesh on the initial cross sections - extrude this mesh along the curves to make up a torus (see second icon in the edit mesh section) - glue the end sections to form a single volume. |
February 27, 2020, 04:17 |
aref
Rep Power: 7 |
Thank you a lot dear AtoHM and Gert-Jan a lot i did your recommendation and i was useful.
blocking strategy, icem 18.1 |
[blockMesh] Velocity,Pressure locked in Blocks | Tobi94 | OpenFOAM Meshing & Mesh Conversion | 2 | December 31, 2019 09:27 |
How to make inner boundaries selectable in COMSOL? | Estiivan | COMSOL | 1 | April 7, 2017 11:03 |
[ICEM] Replay not working properly - Creating the mesh for Free Block. | Wingman | ANSYS Meshing & Geometry | 4 | January 17, 2017 04:57 |
[ICEM] Subtracting One block from another block | shivasluzz | ANSYS Meshing & Geometry | 2 | November 21, 2014 21:38 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
