[ICEM] Dramatic decrease in Mesh Quality After creating Prism Layers? |
November 26, 2019, 14:20 |
Rep Power: 7 |
Hello everybody,
I have used the following procedure to get an unstrucutred volume mesh:
The problem is that I don´t really see what I could do differently? Thanks a lot for your answer and have a nice day |
November 28, 2019, 05:56 |
Stuart
Rep Power: 26 |
This always happens. Your procedure is the best way of making hybrid meshes in ICEM. Smoothing prism layers is difficult. Have you read Simon's Tips & Tricks in Before you start a thread, see if you can find answers here See Slide 62.
November 28, 2019, 10:23 |
Rep Power: 7 |
Thank you siw for your reply.
I have found the following post which helped me a lot and I was actually able to get a quite good quality (badest element 0.31), including the prism layers. So here is the post I am talking about: "I promised you some instructions on improving prism layer generation. Prism generates prism layers by extruding the surface mesh into the volume. As it marches into the mesh, it uses the existing Octree mesh to find it's way. After the last prism layer is generated, the neighboring tet mesh is split, if necessary and the prisms and surrounding tet mesh are smoothed. Most of the problems encountered with prism generation are due to this last step. If you have a refined surface mesh, but the volume mesh expands quickly away from the surface, the neighboring tets after the prism layer may be 4 to 16 times larger than the triangular face of the last prism. This makes it very difficult to split and smooth the mesh effectively. Furthermore, since the prisms are being extruded through progressively larger tets, the smoothness of the prism layers may suffer as well (although this has been improved in version 5.0). With this in mind, I suggest using the 'width' parameter when defining the surface element sizes. The width parameter is an integer value that tells Tetra to refine the elements in the volume next to a surface to be the same size as the surface mesh, up to 'width' elements deep. In other words, if you specify width as 4, Tetra will make the first 4 elements away from the surface the same size as the surface element. To achieve a smooth transition from the last prism layer into the volume, you should specify about 1/2 as many width layers as you want prism layers. So if you want 20 prism layers, use a width of 10. You may refine this based on your own experience as well. A good prism layer has two main qualities; it should have a constant first node height (at least along a given surface) and it should provide a low volume ratio between the last prism element and the first tet. Prism allows you to ensure both of these criteria. The "Initial Height" parameter specifies the distance to the first node. The "Max height over base" parameter specifies the maximum ratio of thickness of the extruded dimension (height) to the edge length of the triangle being extruded (base). Generally, if you assume the first tet is nearly isotropic, a base/height ratio of about .8 will give you a volume ratio of nearly one. If you follow these instructions, you should be able to generate a pretty good prism mesh. The three parameters to remember are "width", "initial height" and "max base over height". Please feel free to forward this to your colleagues and provide feedback to me on this advice." What I experienced: - I got the best results as follows: When I created the prism layers I did not give any initial height as criterion. Initial height and Total height were set to zero. - Then after the prism layers were created in went to the edit mesh tab --> move nodes --> Redistribute Prism Edge and then fixed the inital height to the desired one. Maybe this helps someone. Have a nice day! |
November 28, 2019, 11:08 |
Stuart
Rep Power: 26 |
A rule of thumb is for ICEM element quality > 0.3 is good. But that does not apply to prism element shapes. You should inspect the prism elements in your mesh.
November 29, 2019, 17:58 |
#5 | |
One other thing you can do is increase the chord-wise and span-wise elements just on the surface of the body. But this is of course limited by your computing capability. ps; I prefer hexa meshing over any unstructured methods. |
December 5, 2019, 03:23 |
Rep Power: 7 |
Thank you siw and sheerez234 for your answers.
@siw: You said: "You should inspect the prism elements in your mesh." What do you mean exactly with inspect? With the Quality tool? Or how do you do it? Thanks a lot for your answer @sheerez234: You mentioned that you would increase chord and span-wise elements just on the surface of the body. So you mean that after having my volume mesh I should make the surface mesh finer? Is that even possible? Or dou you mean that I should make the surface mesh I've got from the Octree Volume meshing finer before I create again a Volume Mesh with Delaunay? Sorry, I dòn't get what you mean... Have a nice day! Patrick |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? | Rohith Giridhar | ANSYS Meshing & Geometry | 2 | July 11, 2015 19:04 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[ICEM] Creating prism layer for a badminton shuttlecock model decreases quality | li0012in | ANSYS Meshing & Geometry | 10 | January 5, 2012 02:36 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 23:04 |
