[ICEM] Merge Manually Created Blocks With Extruded Blocks
Like Tree1Likes
  • 1 Post By bluebase
Old   November 12, 2019, 10:35
Post Merge Manually Created Blocks With Extruded Blocks
pamstad is on a distinguished road
Hello everybody,
I have the following issue:
- I want to hex mesh a volute. As it has difficult geometry I created the blocks a follows by hand: Via the edit Mesh tab --> Create Elements, I created manually hex elements (by choosing points) where the geometry is difficult. Then via File --> Blocking-->Create from Unstruct Mesh I got my blocks.
- When I now want to create a block via extrude Face in the blocking tab, the blocks have a different color then the ones from the manual approach and a strange mesh occurs at each interface of an extruded Faceblock.
Does anybody know where the problem is?
Thanks a lot for your help!
pamstad is offline   Reply With Quote
Old   November 19, 2019, 08:03
Sebastian Engel
bluebase will become famous soon enough
Hi Patrick,
seeing your latest thread, i assume you fixed this issue. So this answer might be for the next user to find:
The "problem" is that you can select for which part a new block is created. It is likely, that your fluid part is a different part than the part in which the extruded block is created.
You can avoid this by defining for which part new blocks will be created.
If you already have a mixed blocking, you just can use add to part to collect and move blocks in the wrong part into its designated part.
Best,
Sebastian
aero_head likes this.
bluebase is offline   Reply With Quote
Old   November 21, 2019, 02:42
Hi Sebastian,
Thank you for your answer, and yes the problem is solved
Have a nice day
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 07:05
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
