[DesignModeler] How to add helical ribs to outer pipe surface
Like Tree1Likes
  • 1 Post By jbo214
Old   November 12, 2019, 08:02
Default How to add helical ribs to outer pipe surface
mariam.sara is on a distinguished road
I have a pipe with inner and outer diameters as 6 & 10 mm respectively & length of 1 m. I want to add helical ribs to the outer surface of the pipe as that appears on the pictures? may somebody guide me on how I can do that?
Thanks for reply
Mariam
mariam.sara is offline   Reply With Quote
Old   November 12, 2019, 13:43
Joshua
jbo214 is on a distinguished road
See page 234.
http://www.kkiem.mech.pg.gda.pl/oacm...instrukcja.pdf
Also
https://www.youtube.com/watch?v=dXYbGtpIYI4
mariam.sara likes this.
jbo214 is offline   Reply With Quote
Old   November 12, 2019, 14:47
Many thanks for the answer. At the youtube there is only illustration on how to draw a helical tube but on my geometry, the helical tube added to the outer surface of the pipe? How I can do that? may you mention that to me in sequential steps? I will be grateful for that?
Mariam
Old   November 12, 2019, 14:51
Joshua
Dimension the diameter of the sweep such that it matches with the OD of the pipe. Boolean the two bodies together after the sweep.
Try sweeping something and see what you get.
Old   November 14, 2019, 16:18
I attempted to use Boolean with substract but the process failed and an error appeared as the attached picture? I think the reason is from the helical pipe which looks longer than the pipe extents as shown in the pictures? I am sure that I give the line of the sweep same as that of the pipe length as 1 m? why it appears longer when created? I tried other pitches same thing happen?
mariam
Old   November 14, 2019, 16:24
Joshua
It looks like the outer diameter of your helix is the same as the diameter of the body you are trying to subtract from. This would give an infinitely thin edge, so DM gives you an error. Try tweaking the diameter of the helix and/or the diameter of the circle swept along the path.
Old   November 15, 2019, 02:55
OK but the helical pipe actually exists on the outer diameter of the pipe (As illustrated on my first post) and it looks fit precisely on the outer diameter? as I mentioned in my last post the helical tube seems longer than the actual pipe (see picture) hence the problem as I think with length not with diameter?
mariam
Old   November 17, 2019, 15:52
The advice to avoid tangent conditions and applies to any solid modeling software. Make the helix diameter slightly larger to break though the wall or slightly smaller to leave a small wall thickness. Avoid having two surfaces that are trying to create a zero thickness section.
I did the substract successfully but the geometry looks incorrect because the helical pipe became as grooves while I want it appears like that on the second picture? How I can resolve this problem? any advice, please?
Mariam
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 16:51
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Decreasing surface roughness in a pipe pat FLUENT 0 June 12, 2006 12:22
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
