[ICEM] O-grid meshing problem
Like Tree2Likes
  • 2 Post By Far
Old   August 21, 2019, 06:06
Default O-grid meshing problem
Dyuman Joshi
Dyuman_j is on a distinguished road
I am trying to make a mesh around simple square and similar bodies.
But the meshing is uneven around the mesh.
I am creating the geometry, blocking and using o-grid to create gird around body.
The mesh seems to be distorted. The o-grid is generated perfectly.
I am using pre-mesh params to set up nodes on the edges.
I have tried changing the number of nodes but no change occurs.
Any possible solutions for this problem?
Dyuman_j is offline   Reply With Quote
Old   August 21, 2019, 06:26
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can vary Factor from 0 - 3. Default value is 1. This will control the roundness to outer edges based on the roundness in inner edges.
Use Edit edge command and link inner ogrid edges to outer ogrid edges one by one for all four sets.
Shanaylla and Dyuman_j like this.
Far is offline   Reply With Quote
icem cfd meshing, o-grid
Fine/Turbo cannot open grid built by IGG, Configuration file problem? wkjshon Fidelity CFD 6 March 29, 2016 03:09
[ANSYS Meshing] Problem with meshing around the blade. vijaykamesh ANSYS Meshing & Geometry 1 March 22, 2016 06:20
[ICEM] Problem with meshing half NACA0009 in 3D Eizo ANSYS Meshing & Geometry 30 February 17, 2013 03:40
Problem with staggered grid on numerical simulation gtr84 Main CFD Forum 1 February 15, 2012 08:58
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
