[ANSYS Meshing] contact region problem
Like Tree2Likes
  • 1 Post By sortik
  • 1 Post By Gweher
Old   July 30, 2019, 05:51
Default contact region problem
sortik is on a distinguished road
I think that I somehow don't understand how automatic contact region generation works and how it should be used.
I am facing several problems.
1) I always used DM with one part that was created from several parts trought function Form new parts to create conformal mesh. Even though my model was ok (there were no overlapping faces, no clearances no babd edges/faces) sometimes meshing module created contacts that made no sense (see image contact.jpg). There is no point in this contact to be created. I learned that this could indicade error in the model (either there is a clearance or overlapping or just a bad face). But I am 100% sure there is no problem.
Why is the contact created in the first place? Can I just delete the contact a continue with the simulation?
2) I tried to switch to SCDM but I have so many troubles with it. It looks like the SCDM isn't so precise and creating a model from scratch in SCDM produces so many bad edges, overlaping faces and clearances that a lot of time I am not even able to create a mesh because of bad edges that can't be removed. For example I have one stp model - If i import it to SCDM set shared topolgy to merge and open it in mesh module (CFX) I get a lot of automatic contact regions even though the value is set to 0.000001m.
If I open the same model in DM and create a form new part I get like 75% less automatic contact regions compared to DM.
I just don't get it
Could you please give me any advice? thank you
Svetlana likes this.
sortik is offline   Reply With Quote
Old   July 30, 2019, 06:31
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Sortik,
I suppose that you use "automatic contact" creation which is basically searching for contact pairs within a given tolerance. You can perfectly delete the contact pair and insert manual one if needed.
If you have several parts where you need conformal mesh at part interface you can simply select all the parts in DM > rmb > form new part (this will regroup them under the same part and impose conformal mesh during the meshing procedure and without requiring contact definition). In SC you need to select the bodies > form new component. Then under component properties select "share".
Have fun
Gweher is offline   Reply With Quote
Old   July 30, 2019, 07:58
Hi Gweher,
thank you for your fast response. Yes I am aware of that, but why is the automatic contact created in the first place when the topology is shared and the tolerance is really small? Can I consider it as a badly created contact?
I have no gaps between faces and still there are automaticaly created contacts and I am worried that is because my geomery has some errors even though I checked everything in SCDM.
Old   August 8, 2019, 13:57
Gweher's Avatar
Gwenael H.
Hi Sortik,
It's a bit difficult to say without having a look at the model. Did you also check in SC (with the repair tools) that you didn't have any overlapping faces for instance ?
Old   August 8, 2019, 17:21
Svetlana Tkachenko
Svetlana is on a distinguished road
Contacts are created between bodies from different parts. If your bodies are all in one part, then why do you need a contact region?
Svetlana is offline   Reply With Quote
Old   August 9, 2019, 04:36
Gweher's Avatar
Gwenael H.
You're right, if its in the same part (multibody part) then you don't need contacts as they are imposed directly through conformal meshing at the parts interfaces.
Just need to be careful with SC as when you form a multibody part (rbm > form component) you need to change the behavior under properties > share.
Old   August 9, 2019, 05:11
Svetlana Tkachenko
A bit confused here, what is RBM and SC?
Old   August 9, 2019, 10:18
Gweher's Avatar
Gwenael H.
RMB = right mouse button (typo with RBM)
SC = Spaceclaim (also a geometry editor from Ansys but a direct modeller compared to DesignModeller which is more a traditional history based CAD software).
Old   August 13, 2019, 12:37
MIDHUN
MIDHUN@CFD is on a distinguished road
Send a message via Skype™ to MIDHUN@CFD
use form new part to create confornmal meshes if not dont use FNP .. with form new part there wont be contact regions. If your namings of bodies are same and you use FNM then in fluent all these bodies come as single domain.
MIDHUN@CFD is offline   Reply With Quote
Old   August 13, 2019, 16:41
thanks for your help. I didn't need contacts, however when I formed new part there were always some contacts created. I checked the model a few times and indeed found some errors like extra edges and overlapping faces and also som clearances. It is a bit crazy editing large assemblies in SC since somehow this kind of "errors" are created by SC without you knowing about it.
When I form new part and there is some contacts in mesher I know for sure my model has errors and also there is a high chance that there will be problem with a mesh
Old   August 14, 2019, 04:14
Gweher's Avatar
Gwenael H.
When you form a part in Spaceclaim (i.e. component) you need to change the properties to "share" if you want to have the same behavior as in Design modeller with "form new part":
Have fun
Old   December 26, 2019, 14:35
Manel
Manel is on a distinguished road
Hi Gweher,
Can you please tell me how can i change behaviour to share by using ansys design modeler and Ansys meshing ?
thanks you,
Best regards ,
Manel
Manel is offline   Reply With Quote
Old   December 26, 2019, 14:37
Manel
Hi Gweher,
Can you please tell me how can i change behaviour to share by using Ansys Design modeler and Ansys meshing?
thanks you,
Best regards ,
Manel
Old   May 30, 2020, 02:29
Khan
Khan_CFD is on a distinguished road
Dear Gweher,
I have a doubt on similar lines.
When we create a single part from say 3 parts (and there are 3 bodies, say cuboids present side by side), the contact regions do not appear in the fluent boundary conditions, instead a 'wall' appears between two bodies. Whereas, when we allow 3 parts to remain, 2 contact regions are created. However, we can give the boundary conditions at walls or interface contact regions in both the cases.
The questions is, what is difference between creating a single part and letting different parts be as they are...?
Thanks.
Khan_CFD is offline   Reply With Quote
Old   July 28, 2020, 09:30
zahid ahmed qureshi
zaqureshi is on a distinguished road
hello mr. khan,
i am facing the same issue of contact regions appearing in a single part - multibody geometry. the contact regions are not supposed to arise due to forming of one part. did you find a solution to this problem?
can you please let me know about it.
best regards,
zahid
zaqureshi is offline   Reply With Quote
Old   July 29, 2020, 01:22
Khan
Originally Posted by zaqureshi View Post
hello mr. khan,
best regards,
zahid
My problem was a bit different than yours. My question was about difference between multi part body and single part body. I did not have the problem of contact regions appearing in single part body.
However, I guess you have not merged various parts into a single part in design modeler geometry. If you did so most likely that problem should not happen.
I came to know that single part helps in making conformal mesh between various body parts.
Regards.
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 07:51
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
Contact problem (boundary condition) for stress analysis Hisham OpenFOAM Pre-Processing 2 September 21, 2011 06:56
Problem in setting porosity region for rhoPorousSimpleFoam run_cfd OpenFOAM Pre-Processing 1 May 31, 2011 10:02
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
