[ICEM] Meshing a convergent-divergent nozzle (Laval) with Boundary Layer
Like Tree2Likes
  • 1 Post By Simser
  • 1 Post By Gweher
Old   July 20, 2019, 06:45
Default Meshing a convergent-divergent nozzle (Laval) with Boundary Layer
Simon
Simser is on a distinguished road
Hello Everyone,
I already simulated a nozzle with laminar flow and no viscosity but compressible and got good results (correlating with 1D-Flow Theory).
The geometry looks as follows and is extruded 2mm in z-direction (quasi 1D Flow). The Inlet is about 12mm high and it is 400mm long in total. The pressure drop occurs 120mm after the smallest crossection (between the green dots).
Now I want to simulate it with viscosity and friction at the nozzle wall. All other sides are symmetries.
But i dont know how to get an estimate of the Boundary Layer thickness and therefor how thick to make the boundary layer block. How do you guys proceed when meshing such a geometry?
Should I use a block with constant thickness along the whole wall or change the height of my boundary layer block along the x-axis?
Thanks
Simon
Svetlana likes this.
Simser is offline   Reply With Quote
Old   August 8, 2019, 14:14
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hello Simon,
I would create a biased seeding along the vertical edges for your BL. In case of turbulent flow you can estimate the first layer height using y+ calculator (https://www.cfd-online.com/Tools/yplus.php).
y+ is not typically mentioned in laminar flow but can also can be used if defined properly. For instance you can calculate the max displacement of the boundary layer from the Blasius solution and decide how many points you need in order to cover this. There are some interesting posts covering that topic on this forum, you should definitively have a look at it
Gweher is offline   Reply With Quote
boundary layer, boundary layer mesh, icem 2d blocking
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Convergent Divergent Nozzle with Separation ookalkan CFX 0 January 31, 2011 18:12
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
