[Other] SpaceClaim automatically merges bodies |
July 18, 2019, 06:02 |
Robin
Rep Power: 7 |
My setup is a geometry defined in SpaceClaim with dimensional input parameters. This is meshed with a Workbench project in Fluent Meshing Mode and finally solved in Fluent.
My problem is, that I want to have a defined mesh size in one fluid body of my domain. The body is connected directly to other bodies and if I change anything within that body SpaceClaim automatically merges all my bodies to one. If I use the named selection for the surfaces of that region, I can only define a Body of Influence with is not treating the inner cells the same way. Do you have any idea how to overcome my problem? As far as I'm aware I can't define a zone in SpaceClaim nor prevent the merging if I change a parameter. Also, a zone chosen for the body mesh size in Fluent is not kept when I update my dimension parameter. Thank you! |
August 12, 2019, 09:36 |
Gwenael H.
Rep Power: 20 |
Hi Robin,
I suspect that you have enabled the "share" property inside of Spaceclaim. You should check at the model properties in Spaceclaim and change the "share Topology" property to "none" (instead of "share" / "merge"). Have fun |
September 18, 2019, 10:21 |
Robin
Rep Power: 7 |
Thanks for your reply, it wasn't the cause of my problem. Though it guided me in the right direction.
I didn't realize that it happened only, when I used the pull tool. I figured that there is a "No Merge" Option in the properties of the pull tool. Now my geometries stay seperated the way I want. This is the setting: |
October 14, 2019, 07:48 |
Gwenael H.
Rep Power: 20 |
Hi Robin,
Yes you're right, didn't properly read your initial post otherwise I would have pointed you towards the solution you've written. I also faced that problem and I personally change the default pull behaviour to "no merge" as I'm using it more often. In case you need it you can change it under: File > SpaceClaim Options > Advanced > Pull Tool, in the option "Default extrude Behavior" select "No Merge" Have fun |
body size, fluent, merge, meshing, spaceclaim |
[ANSYS Meshing] ANSYS 2D Geometry/Meshing Plugin Error: Attach Failed, No Valid Bodies Found | cdase | ANSYS Meshing & Geometry | 0 | August 26, 2018 15:31 |
[ANSYS Meshing] The number of bodies are increased automatically when i open the mesh | masoudmeskin | ANSYS Meshing & Geometry | 3 | January 16, 2017 23:00 |
[ANSYS Meshing] How to make ICEM meshes of different bodies automatically become one part? | Sean Ling | ANSYS Meshing & Geometry | 0 | May 17, 2016 13:47 |
[DesignModeler] [ANSYS Geometry] Error: Operation would result in non-manifold bodies | -roberto | ANSYS Meshing & Geometry | 0 | April 10, 2015 07:33 |
[Other] SpaceClaim: unit changes automatically when opening 2D dfx, dwg files | abdullahkarimi | ANSYS Meshing & Geometry | 0 | March 3, 2015 11:37 |
