[ANSYS Meshing] How to determine which mesh to use in 3D |
July 15, 2019, 11:50 |
Rep Power: 7 |
Hello everyone,
I have noticed there are a variety of meshes available to use. For example, tetrahedral, hexahedron, wedge, pyramid, and polyhedron meshes. Is your choice of mesh mainly based on the computational time? What other factors affect your mesh choices? Thank you. |
July 16, 2019, 05:19 |
M
Rep Power: 13 |
I do alot of free-surface water simulation for customers. Two main aspects are computation time and high quality post processing.
Both is good with hexa meshes. They take quite a lot less mesh cells to fill a given volume and give very smooth visual of the water surface when using a proper refinement in this region. |
mesh |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 06:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 17:59 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
