[ICEM] Meshing with ICEM
Like Tree3Likes
  • 1 Post By shereez234
  • 1 Post By bdahsan007
Old   May 23, 2019, 22:32
Default Meshing with ICEM
Lucas
lordluan is on a distinguished road
Hi there,
I am having trouble to mesh some geometries in ICEM. Anyone have a book or tutorial recommendation? I would like to be able to mesh anything, but the lack of theory prevents me from doing it. For instance, I don't know how to choose a Scale Factor, max element and when to use Curve Mesh Setup and Surface Mesh Setup or when I should use blocking. I've already google it, but I couldn't find anything.
Thanks in advance
lordluan is offline   Reply With Quote
Old   May 26, 2019, 01:38
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Originally Posted by lordluan View Post
Hi there,
Thanks in advance
A good place to start ICEM practice will of course be its own tutorials (just like any other software). Many people jump right into their own specific problems they are trying to solve without doing this. But this is the recommended way.
If you want to learn ICEM by trial and error method you can try something in ICEM once you get an error or if you are stuck search for that specific problem in threads posted on this particular forum. Be it Octree, Delaunay, Structured, Unstructured, Multi-Block etc etc I bet somebody else has faced that problem before and it has been discussed and resolved to some extent here.
Another way is to search for thread posts from "Far, PSMYNN, Gert-Jan, bluebase, diamondx" , you know some legends around here . Bet you can get some real nice tips.
Also, ANSYS have got a series of videos called "how to". search in Youtube for them. There are many other channels in YouTube for ICEM mesh generation as well including poor my channel too .
Good luck and hope its speedy learning for you.
lordluan likes this.
shereez234 is offline   Reply With Quote
Old   May 27, 2019, 21:12
Lucas
Thanks very much for answering my question. I've been doing the tutorials and my doubts emerged because I was following the tutorial. I'll follow your advice and visit your channel.
Old   June 4, 2019, 03:25
Cool Icem cfd
Ahsan
bdahsan007 is on a distinguished road
Try this PDF for refence.
https://itrss.mst.edu/media/informat...l%20Manual.pdf
bdahsan007 is offline   Reply With Quote
Old   June 5, 2019, 08:58
shereez234's Avatar
M Sereez
Ps: Do you notice the post as a sticky thread on the top of this forum?
"Before you start a thread ... " ? There exists many tips and tricks
icem 18.1
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 10:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 09:24
