December 3, 2018, 10:22 |
Mesher faild to initialize
Rep Power: 8 |
Hi, I have this problem with my ANSYS Mesh , when i try to create an inflation on any surfaces like what you see at the images, after clicking on generate , ANSYS get this errors
1.Mesher failed to initialize 2.One or more non sweep able bodies have sweep controls and can not be sweep. 3.Mesh generation failed because of poor quality or incorrect input. I tried with ANSYS 18 and 19 Even i tried it at different Computers. An Also , i made the quality a lot better or worse! I designed a simple geometry to show you whats going on: Inserting an Inflation: After Click on Generate I need your help , Any advice on this problem or inflation will be helpful Thank you all |
December 8, 2018, 17:15 |
please help me fast
Rep Power: 8 |
Hi, I need your help at this problem , can anyone help?
December 11, 2018, 09:52 |
Rep Power: 9 |
if it is a sweepable body then you select a face and edge.
In that case it doesn't seem to be swepable. You must select the body and the lateral faces to have inflation. |
December 13, 2018, 16:32 |
how to sweep the body?
Rep Power: 8 |
Hi, I want to inflate on a none sweepable body, is it possible?
Can I sweep the body ? I tried changing the method to sweep and It didn't work, still same error. |
December 14, 2018, 06:37 |
Rep Power: 9 |
when on mesh, right click/show/sweepable bodies to see if a body is sweepable.
if it is sweepable it will be colored in green. then if you want to inflate a sweepable body you have to select the sweep method and select on scr/trg selection "manual source" and add the appropiate face. rigth click on sweep method -->inflate this method ecc. if it is not sweepable in general you a have to use another method or decompose further the geometry. Of course you can inflate a non sweepable body. insert inflation, select a body (not a face like for sweep... you are not 2sweeping a face") and the surfaces where inflation layers must be created. ps. if you search on the meshing manual you'll find answer on this kind of questions |
ansys, inflation, mesh, tet |
initialize from data file | robboflea | FLUENT | 4 | June 20, 2018 10:41 |
[ANSYS Meshing] ANSYS Mesher cann't update geometry from parameter set | M.Shousha | ANSYS Meshing & Geometry | 4 | November 25, 2016 06:11 |
Trimmed cell mesher coordinate system | shammon | STAR-CCM+ | 5 | September 22, 2016 21:21 |
[ICEM] 2D Airfoil Patch Dependent Mesher Ignores Curve Sizing | khoopes | ANSYS Meshing & Geometry | 0 | February 2, 2013 11:28 |
[ICEM] parallel mesher error | beguxa | ANSYS Meshing & Geometry | 2 | February 1, 2011 02:56 |
