[Other] Diverging after good initialization when conducting CFD of Diffuser using ideal gas
Like Tree1Likes
  • 1 Post By TomD
Old   October 24, 2018, 09:06
Default Diverging after good initialization when conducting CFD of Diffuser using ideal gas
MWRS
waseeqsiddiqui is on a distinguished road
ANSYS Fluent.
I have Total Temperature, Total Pressure, Static Pressure, and Mach at inlet of duct. I need everything mentioned above for outlet, high priority of need is total pressure at outlet. So I used Pressure inlet (Total Temperature, Pressure and Static Pressure and direction normal to surface) and mass flow rate outlet (I have it same as inlet). Also Operating Condition set to Zero. When density is set constant, the solution works good but since it's Mach 0.6, ideal gas is required. So I used Ideal gas and it gives floating point error at first iteration after an incredible initialization to e-08!
Please guide.
waseeqsiddiqui is offline   Reply With Quote
Old   October 24, 2018, 09:28
Tom David
TomD is on a distinguished road
First of all, this post should probably be moved to the Fluent sub-forum
can you post pictures of your mesh, geometry and BC specifications?
Have you tried using your constant density solution as the initialization for the ideal gas solution? meaning, running few iterations until you converge with constant density, than switching to ideal gas model.
Also, try incompressible ideal gas, that means that the density changes only due to temperature changes and not pressure changes. this is incorrect of-course but it will show you if your problem originates from the temperatures within your domain. do you have heat transfer other than friction heating?
Also, try to look at your inlet and outlet conditions and make sure you dont over-constraint the solution
waseeqsiddiqui likes this.
TomD is offline   Reply With Quote
Old   October 24, 2018, 09:31
MWRS
Sorry for not posting in Fluent sub forum.
Very well noted. Thank you for the suggestion.
I'll try both methods.
If doesn't work, will post specs.
Old   October 24, 2018, 09:32
MWRS
No I dont have any heat transfer.
Actually only mass flow rate is common for both inlet and outlet.
Old   October 24, 2018, 09:52
MWRS
Mesh and Geometry are of a S shaped Diffuser
At Pressure Inlet, I placed
Total Pressure at the respective field.
Static Pressure at the initial Guage Pressure
Total Temperature at the respective field.
Direction Vector as normal to boundary.
At mass flow rate outlet, only the respective value of mass flow rate.
Operating was set to Zero.
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
Ideal vs constant gas model chris12345 STAR-CCM+ 1 January 2, 2013 07:49
Is it worth it? Jason Bardis Main CFD Forum 47 July 27, 2011 05:52
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
Good CFD Books, FAQ Jonas Larsson Main CFD Forum 11 April 16, 1999 17:43
