July 25, 2018, 10:31 |
Sweep Method and Inflation
Rep Power: 14 |
Hi
I am trying to generate a mesh for a Rotor Turbine with 20 blades and i am using Sweep method (Hexa mesh) And I am encountering few problems 1. I am trying to generate some inflation layers and sweep method is not allowing me to generate inflation layer around the Blade walls. I used by named selection. 2. I am using now the Curvature option in advanced size function, and it atleast generates some mesh. But when I use proximity or curvature and proximity, its not working, its taking too much time and crashing due to insufficient memory. 3. When I use simply use the sweep mesh, my blade tip has only one cell, (which is 2mm) and I use edge sizing for the blade tips and divide the edge into 4 divisions and then I get 4 cells along the blade tip. But the mesh around it is crappy by doing so, Is there any way to get rid of this or is it ok to keep it like that ? Can someone tell me what could be the reason for all these ? |
July 25, 2018, 20:51 |
Rep Power: 8 |
As far as I know, sweep mesh method is for geometries like pipes, with fairly constant cross section, and turbine is not such case.
You could try MultiZone or cutting the geometry and applying sweep method to duct and different method to the rotor. |
July 26, 2018, 04:59 |
Rep Power: 14 |
As per Ansys Support Multizone and Sweep is almost similar and they suggested me to try with Sweep
July 26, 2018, 07:34 |
Rep Power: 8 |
If you have support available then go with their advices.
From your description and my experience, I still think that sweep is not a way to go. |
July 26, 2018, 13:35 |
Rep Power: 11 |
You generally need a meshing program specific to turbomachinery to make a hex mesh on turbomachinery geometry. TurboGrid from ANSYS is one. or Numeca has some really good tools too.
Just go tet mesh and the inflation should be much easier to achieve if you are just using ANSYS meshing. |
June 30, 2022, 13:23 |
CFD
Rep Power: 4 |
The Sweep method is perfect for Rotor as far as you apply inflation on the faces not the body. You can apply inflation around blades on the source face and select edges of the blade as the boundaries. This way you can get inflation around the blades.
[ANSYS Meshing] inflating sweep method | blazejpop | ANSYS Meshing & Geometry | 7 | March 11, 2019 05:25 |
Inflation, invalid method | sdarmayuda | FLUENT | 0 | October 27, 2017 10:19 |
[ANSYS Meshing] Problem with sweep Method | MrNavierStokes | ANSYS Meshing & Geometry | 4 | November 7, 2016 15:08 |
[ANSYS Meshing] Hex dominant method and local inflation | carlp | ANSYS Meshing & Geometry | 8 | July 12, 2012 09:02 |
Inflation Mesh Possible with Multizone Method for this Geometry | jonny_b | ANSYS Meshing & Geometry | 2 | September 16, 2011 17:20 |
